LED in Tails
Old Jan 19, 2008 | 05:43 PM
Raptor05121's Avatar
LED in Tails
Okay, I'm looking to get the dual-curcuit LED lights for my main tails. I hear to do this some reisitor is needed so the system dosen't flash at ultra-speed?
Where can I get this resistor at?
Old Jan 19, 2008 | 07:54 PM
NoLongerJeepin's Avatar
radioshack should have them
Old Jan 19, 2008 | 09:44 PM
hm... ill look into this.
just ordered the dome LEDS and my scangauge 2.
if i can find this thing ill get the 3rd brake light and main tail LEDS too
Old Jan 20, 2008 | 11:47 AM
fireman137's Avatar
Any store that has led bulbs should also sell load equalizers or balancers, i.e.
http://frickinbrite.com/catalog/index.php?cPath=44
or
http://autolumination.com/equalizers.htm
Conversely you can just switch out the flasher with one designed to handle led bulbs, you can find them on the same page as the second link above - switch one flasher instead of adding four equalizers.... save money, time, and amperage.
Old Jan 21, 2008 | 07:43 PM
05BlackFX4's Avatar
www.oznium.com they sell great items and I moderate on their forums....they should have all kinds of resistors that you are looking for...if not, PM the owner, he will build you one
Old Jan 21, 2008 | 07:48 PM
Oznium is great, I just purchased the hard-sided dome LED light. If it's as easy as I think it will be, I will be buying from them again!
Old Jan 21, 2008 | 07:59 PM
scottbigred's Avatar
just get a few resistors from radioshack, why spend money on a new flasher? resistors are way way way cheap.
Old Jan 21, 2008 | 08:03 PM
how many ohms and what wattage?
Old Jan 22, 2008 | 01:06 AM
that i dont know. take a DMM and test your stock bulb then your led and make up the difference and figure out what kinda power is gonna be runnin through it to find out what wattage you need. someone else may have a better answer as to exactly what you need but thats all i got. sorry but i hope it helped a little
Old Jan 22, 2008 | 10:55 AM
Dad dosen't want me running around messing with the stock wiring on the truck. He's afraid ill short something and kill the truck...
Had to buy and install my Fire and Ice without him knowing. Don't even get me started on the PA system...
Old Jan 22, 2008 | 12:55 PM
well when have the harness pulled out to put the bulbs in just snip the wires a few inches from the connector and strip the wire back and either solder or use a crimp connector to put the resistor in and get some shrink wrap to put over it and its a water tight seal and if done correctly should never come undone. just remember to put the shrink wrap on before you finish the connections. damn i hate when that happens. get it all done and have to cut it apart again lol.
