change guage lighting????
Originally Posted by kwfireman10
can i change the color of the guage lighting to another color? if so how???
Originally Posted by Copperhead64
Honestly i dont remember how the person did it, but i do know that it was a major project and took alot of work and time. Have you tried using the search function to find that thread?
Don't know if it's different in the pre-2004 models, but 2004+ the color is from a film in the cluster. Colored bulbs do nothing, you have to disassemble the cluster and scrape off the film. Another member here did it and ruined their odometer display in the process.
i've seen it done numerous times...
example on 97-98:
(stock has the aqua/teal film)
http://i174.photobucket.com/albums/w...Picture004.jpg
Originally Posted by Grafix Ink.
example on 97-98:
MUST.....HAVE.....
Where in the world did you find that?!!?!?
MUST.....HAVE.....
posted on another forum... bud, like i said... just replace your cluster bulbs with wide angle LEDS(to avoid hotspots like shown) and your set.
Originally Posted by SKRWZ
Get your facts straight Graffix .. The only reason it looks like thier is "HOT SPOTS" in the center of this is the the #74 bulbs were not used a small led was fit in it's place with the proper LED used you should not get the "HOT SPOT" look
i have tested it myself recently... and with regular #194 leds - not wide angle you will get hotspots.
Thats the best the pic could be taken that night its not as uneven as you think
but wide angle leds... imo are still the best choice.
has anyone tried white leds? i took apart my non tached cluster and noticed the film is actually blue.
