Aux. Reverse lights?
Originally Posted by j2h1
Here is my reverse lighting. I just put the LED's in the mudflaps this week and they do help light up the path.
Nice job!
- Jack
BigRed, do you have the 7 pin connector? All I did was use a tap in on the wires. You can also find what wire is your reverse on the taillights and tap in to that. I don't know the wire colors off hand. wrap the tap in with tape when done.
The mudflap lights are a unit. I got them from here: http://www.missgrizz.com/productline...hting_kit.html there are pics in my gallery if you didn't already see them. I still didn't hook up the reds yet.
I need some better backup lighting on my PU ('02 F150 KingRanch). I first considered buying a "fire and ice" type LED strip, but I've read in other f150 forums that they don't put out enough light to do any good.
So now I'm thinking of getting one of the White Night units, but thought I'd see if anyone here has experience with either of the following backup lights:
http://www.northerntool.com/webapp/w...7403_200337403
http://www.cabelas.com/cabelas/en/te...0842&noImage=0
Lastly, is there any reason why I couldn't take a pair of running lights and mount them to the bottom of the bumper? I have a 7-pin trailer connector, so getting power to the lights while in reverse shouldn't be a problem. Are there any legal issues to consider?
Thanks!
Steve
Thanks!
Steve
Looks sweet!!
I just mounted to PIAA 4x6" lights off the bottom of my rear fender, boy are they bright!
If you dont mind cutting into the bumper then this works well too. Both my dad and my brother have it, they marked a place in the bumper and drilled a hole, and mounted tow PIAA 004XT in there. Very bright, and can take those tale gaters right off your tail, ill try to get some pics soon. Hope this helps anyone!
