Fogs behind the grill
Old Mar 25, 2009 | 11:14 PM
  #76
ltz400racer's Avatar
Originally Posted by TommyRox
So if I understand it - Home Depot has the parts to make the mountand it all bolts together - no welding etc...I love it !!!! Does anyone have the time that has done this to put together a small short but sweet diagram of this wonderful invention?
i can make one for everyone... ill try to have it by tomorrow..
ill do it my way, and the others way..
if you want to do it my way, just go to lowes and pick up some L brackets (4) mine came pre- drilled... then just get some bolts, and bolt them together to form a Z... unless you want it to be one bracket. i dont think it matters because you cant see it anyway with the hood closed..
-LTZ
Old Mar 25, 2009 | 11:19 PM
  #77
NoLongerJeepin's Avatar
Do the lights shake around a lot when going down a bumpy road?
Old Mar 25, 2009 | 11:28 PM
  #78
ATOM's Avatar
i like your design, but i hate how close those bolts are to the cooler, maybe if i do this, i will weld them together.
Old Mar 25, 2009 | 11:42 PM
  #79
no, not at all. the two brackets stacked on top of each other are about a 1/2 inch thick, so thats another plus about it.
i know, i hated it too.. which is why i cut them down, so they now have 3-4 inches between the brackets and the radiator. i dont think you would need to weld them, but if it makes you feel safer about it, then its a good choice
thanks for the comments
-LTZ
Old Mar 26, 2009 | 04:20 PM
  #80
SmokeyBear's Avatar
I had them mounted on the bull bar but they flopped all over the place because of the flimsy mounting brackets so I moved them. Here is how I did mine. For you H-bar grille guys like me.
I used a piece of c-channel aluminum and bolted it to both headlight mounting points.
Here's a closer look. I took a grinder and lopped off the top part of the c-channel where the light mounted. It's sturdy as can be and no more flopping.
Old Mar 28, 2009 | 09:12 PM
  #81
ARileyOSU's Avatar
It surprises me that with all of the custom designs, no one has actually marketed a kit that would fit behind the grill. I built one for mine and it is a little different still. If anyone wants the plans I drew them up as I went. Just PM me and I will shoot them to you.
-Andy
Old Mar 24, 2011 | 05:19 PM
  #82
countryman777's Avatar
Question light color and the grill affecting it?
I have been wanting to do this for a while but since I have HID headlights I would need spot lights that match that color. Where could I pick up some nice flood lights that are that color for a decent price? Another concern of mine is, does the grill not affect the light some what? I ask these questions because I am new to add on lights like this.
thanks,
Old Mar 24, 2011 | 09:33 PM
  #83
thanks,
Another thing I am wondering when buying these lights to go through the grill is do I want driving or spot type lights?
Old Nov 5, 2012 | 09:15 PM
  #84
ryanfralic's Avatar
All yall's lights look sweet!!
Has anyone ever put them behind the grill on a '92?
I would like to put lights behind my grill and also the cab clearance lights.
