Painting grill
Old Mar 7, 2007 | 10:38 AM
blkmgk's Avatar
Painting grill
I would like to paint my grill white, what is the easiest way to do this and is there a special paint I should be using, or do I go out and by an aftermarket grill(who and where)? I have a 01 F150 Supercab Lariat.
Old Mar 7, 2007 | 11:20 AM
thais0n's Avatar
If you have the honeycomb grille.....just clean it really well to get all the bugs and whatever oils might be on there. Use dishwashing soap and then rub it down with rubbing alcohol. Spray some coats of primer and then 3-4 coats of white paint and then some coats of clear.
Use a paint thats designed for plastics - Duplicolor is usually a good brand.
Old Mar 7, 2007 | 06:13 PM
anthny2040's Avatar
really easy just make sure you get all the oils and armor all off.
Old Mar 7, 2007 | 06:29 PM
mgsalida's Avatar
There is a good post in this forum from Patman03 with some pics and tips on removing the grill insert from the surround. I painted mine black and I used Krylon spray for plastic.
Mike
Old Mar 7, 2007 | 10:59 PM
blkmgk's Avatar
Thanks for the great tips
Old Mar 7, 2007 | 11:58 PM
nd041189's Avatar
yeah i would be interested in doing this too...just take her off and get it done in one day or what? i would like my "H"-grille painted only though...not my honecomb behind it too.
Old Mar 8, 2007 | 12:32 AM
See sig for my thread
Old Mar 10, 2007 | 11:40 AM
blkmgk's Avatar
That looks awesome. One last question for you though. How do I take the grill off, is it fairly simple and how long do you let the paint dry for?
Old Mar 12, 2007 | 08:20 PM
nd041189's Avatar
not sure but i would like to know also...
anyone?? how long do you let the paint dry for?
i have a 2006 and i am going to paint the H-style grill this weekend..any tips on how to get it off?
Old Mar 17, 2007 | 07:14 PM
nd041189's Avatar
anyone?? what is the best paint? should i paint my honecomb behind my H-grille (bar-style) red along with the H-grille, or should i leave the honeycomb black?
Old Mar 17, 2007 | 08:49 PM
mgsalida's Avatar
I used Krylon spray paint that is made for plastic. I think leaving the honeycomb grille black would look better.
Mike
Old Mar 18, 2007 | 09:37 AM
nd041189's Avatar
should i use a Krylon primer as well as Krylon clearcoat? should i scuff it at all?
or........
have you heard of duplicolor fusion? i guess it is supposed to be applied with no primer and no clearcoat. they say just a couple layers of the fusion paint and it has a chemical reaction with plastic and stays....??
hmm
Old Mar 18, 2007 | 11:06 AM
mgsalida's Avatar
or........
hmm
I've never used the Fusion paint but.....I think if you prep it right, primer it and paint, almost any paint will last. I didn't clearcoat mine but I would suggest using the same brand of primer, paint, clearcoat if you go that route. Sometimes mixing brands can affect outcome.
Mike
Old Mar 18, 2007 | 02:01 PM
nd041189's Avatar
ok thanks for your help mike. should i scuff it up at all first or no?
Old Mar 18, 2007 | 02:05 PM
sorry i didnt make it back to this tread until now. Well Ive got instructions in that thread on how to pull off the grill and surround i belive....
and i just washed the grill really well, dried in the hot sun for a few minutes while i shook the paint up. I used some paint from autozone that was designed for interior/exterior plastic. Gloss black, no clear coat. I will probably put a clear on when i am done with my project grill.
-Patrick
