HELP!...What front bumper is this??
Old Apr 16, 2006 | 10:05 PM
iwashmycar's Avatar
I am looking to replace my front bumper on my 98 F1 after a little accident.
The one on there now is painted....and after sorting out all those damn chrome ones i have come across one on ebay...
They say it is a 97-98 and thats it!
It looks like it has the 4x4 driving light holes, but it has a uniform edge on thefront?....from what i've seen, the 4x4 ones have a slight 'set-back' over the center or something..
is this like in-between the 2wd and 4x4 bumper?, or is it missing all the other peices and looks weird
this is the only pic they had
-Adam
Old Apr 17, 2006 | 08:58 AM
kingfish51's Avatar
It sure looks like the 97/98. The bumper is concave and is a straight line across the top. The 99-03 were convex and had a dip in the center section for a larger grill.
Also only the 4x4s came with fog lamps, so this is for a 4x4.
Edit/Delete Message
Old Apr 17, 2006 | 09:50 AM
iwashmycar's Avatar
well, on the 97-98 4x4 bumper there is the set-back on the front, not just where the bigger grille is on the 99+
this is a 98
and here is a 99...
totally looks like the 97-98 fogs, with a 99+ smooth front...
Old Apr 17, 2006 | 04:11 PM
iwashmycar's Avatar
The guy said it had a smooth top, like the 97-98 so....
i guess it'd look a little like this haha...what do you think??
Old Apr 17, 2006 | 09:06 PM
kingfish51's Avatar
The bottom air dam does look a bit different, but I would say they were the same.
Old Apr 18, 2006 | 12:21 PM
iwashmycar's Avatar
alright...turns out it is a custom bumper...basically a 4x2 bumper with fog holes.
thanks kingfish for the input!!!
Old Apr 18, 2006 | 12:25 PM
you should upgrade to the 99+ front while you are buying parts anyways, unless you just love the 98 front.
-Patrick
Old Apr 18, 2006 | 01:32 PM
iwashmycar's Avatar
-Patrick
that would just involve the actual bumper and the grille assembly...correct??
what i REALLY want is a newer STX front with the round fogs
...but they seem to be nearly impossible to come across
Old Apr 20, 2006 | 02:17 AM
yea grill, and bumper covers, i dont know if the bumper itself actually converts over or not. I wanted to find a cheap used STX valence, because they are fairly common, compared to Harley or Lightning....
someone showed me this site the other day
http://www.trademotion.com/partlocat...03&catalogid=2
That has the entire Lightning cover listed as 50 bucks more then just the STX valence is...
So its not even worth it to me to pick up an STX valence, if its just 50 bucks more for the Lightning bumper.
-Patrick
Old Apr 20, 2006 | 09:56 AM
iwashmycar's Avatar
the only problem i see with using a Lightning bumper cover is that it seems that you'd almost HAVE to have some other ground effects to make it flow right, since the Lightning one is lower...although i could be wrong
Old Apr 20, 2006 | 01:11 PM
I personally think it looks fine with out it. Yes it hangs just a little lower then the factory one does, but with a little bit of modding, you can also close the gap under the grill a little, and mount it higher.
This is a gallery of a guy on here with a L bumper on a lowered Screw (no ground effects)
https://www.f150online.com/galleries...y.cfm?gnum=486
And i believe he just mounted his, ive only seen a few people that have the bumper mounted up higher.
-Patrick
