Wax on black plastic
Old Feb 15, 2006 | 01:37 PM
davidlem's Avatar
OK so I waxed the truck for the first time since I bought it in 2004. I used an orbital buffer, also for the first time. Needless to say, I got some wax onto the black plastic parts like the door handles and part of the side mirrors. Then I went over all the black plastic with an exterior plastic/rubber product from Mothers. After about a day those areas that got some wax turned grey, while the rest stayed nice and deep black. How do you remedy this?
Old Feb 15, 2006 | 01:46 PM
Genesys's Avatar
Talking Black Plastic
I want to say I heard that peanut butter does the trick as well as the Mr. Clean Magic Eraser. I am planning on detailing mine this spring when the weather settles down a bit.
Old Feb 15, 2006 | 02:42 PM
dmelchi2000's Avatar
there is a product that mothers makes called Back to Black and it will get that back to the original color
Old Feb 15, 2006 | 03:07 PM
I have used Back to Black and I do not recommend it. It looks great for about 2 weeks, then it turs white in the crevices of the surface grain. Makes it look grey all over till you use it again. It caused the very thing I was trying to avoid. When I poured it out of the bottle and saw it was milky white colored, I started not to use it. I wish I hadn't.
Old Feb 15, 2006 | 03:19 PM
davidlem's Avatar
I also have a bottle of Back to Black and experienced the same thing on my last car, it looks amazing for a period of time, then makes everything look terrible until you apply it again.
Old Feb 15, 2006 | 03:22 PM
KingRanchMan02's Avatar
According to my 2002 owners manual.
PLASTIC (NON-PAINTED) EXTERIOR PARTS
Use only approved products to clean plastic parts. These products are
available from your dealer.
For routine cleaning, use Detail Wash (ZC-3–A).
If tar or grease spots are present, use Extra Strength Tar and Road Oil
Removal (B7A-19520–AA).
FWIIW, I have not used either of these products.
Old Feb 15, 2006 | 09:11 PM
RedDragon's Avatar
Bug and Tar remover works great! We detail motorcycles and have a friend that does cars and we both use the same stuff.
Old Feb 16, 2006 | 12:25 PM
ZAXJAX's Avatar
The best thing out for wax on your plastic trim is ..........................a pencil eraser!
Works every time, then hit it with the Back to Black. The Back to Black only works for little, it really only covers it. Then it's back!
Old Feb 23, 2006 | 10:44 AM
yankeesfan81's Avatar
Davidlem please check your email. Thanks
Matt
Old Feb 24, 2006 | 03:49 AM
pineapple's Avatar
I also use the pencil eraser method. Works real good. Always keep a wet rag handy when applying wax to wipe off any wax that that gets on plastic parts.
Old Feb 24, 2006 | 10:18 AM
GIJoeCam's Avatar
Indeed, peanut butter works wonders. A rag with dawn dish-soap should work too, but it will also strip the wax off your freshly-waxed paint should it get on there.
-Joe
Old Feb 24, 2006 | 10:21 AM
ronco's Avatar
Davidlem,
I have a black 04 reg cab that I wax every 3 months. I have ran across this same issue. One of the best products that I have found is Meguiars #39 vynil cleaner. I have found this product to work the best. comes in a spray bottle that I apply to cotton towel then wipe on then let sit for 20-30 seconds then wipe off. I have not been able to find any locally so I oder direct from Meguiars. Hope this info helps
Old May 1, 2006 | 08:41 PM
XTRUKY's Avatar
Peanut Butter
Wipe it on with your finger, wipe off the excess with the same finger and stick it in your mouth, eat the excess.
Then when it dries, use an old toothbrush to polish off the dried peanut butter
Old May 1, 2006 | 10:36 PM
BLUE20004X4's Avatar
It doesn't get any cheaper than this. take an old toothbrush or make the one your using the old one and a little water. Just brush it off, circular motions Danielson, and it'll do it. A little tedious, but it erases mistakes. Never tried the eraser, sounds good too.
