lightning products
Old May 31, 2001 | 04:35 PM
WhiteyFord's Avatar
Question
Hey King would you happen to have the numbers for them 01L headlights and blinkers for the front of the truck i have the rears in already!!PLease Please thanks
<font face="Verdana, Arial" size="2">Originally posted by King James:
I already got the headlights. What tabs are you talking about?
</font>
Old May 31, 2001 | 04:43 PM
WhiteyFord's Avatar
Question
would you still happen to have the part numbers for the headlights on the 01L i have a 2001 supercrew and i want them headlights and blinkers in the front please help thanks!!!!????
<font face="Verdana, Arial" size="2">Originally posted by ford6mann:
King James: When you do get these '01L parts, here's a tip for all '97& '98 F owners. When installing the headlights, you will have to reuse the headlight adjusting bracket in the '01 lights. You will notice that there are tabs to hold them, which are not needed on the newer models. I have a '97, and I had to do this. When installing them after this is done, make sure to leave the bulb and retaining ring on the assembly, since the opening is positioned over a little bit from yours. Also, make sure the tabs don't go in crooked, otherwise you will crack the assembly tabs on the aligning bracket. Take your time, and it'll look great! Good luck. P.S., I got mine through the dealer, and had to pay the higher cost after May 1 for the second lamp. Bummer.</font>
