Headlight switch removal
Old Dec 17, 2000 | 05:24 AM
Cpt1's Avatar
Post Headlight switch removal
Does any1 know how to remove the small pannel that the headlight switch and dimmer are located. Im looking to add a wire to the dimmer and i figured the best place would be right off the dimmer itself.
Thanks ahead
Old Dec 17, 2000 | 11:23 AM
GIJoeCam's Avatar
Post
The wcover plate is actually a part of the switch. If you use a little screwdriver at the notch in the bottom center, you should be able to pop the whole switch out. I mangled mine pulling it out because the clip in the upper right corner wouldn't release. There are cctually 3 clips: One at bottom center, one on the left side, and one on the top right corner. If you can't get it to pop out, don't force it! (Experience talking again) Pull off the bottom dash panel (about 12 bolts or so) and try pushing it out from the back side. That still didn't work for mine, and I mangled it in frustration! Then, once you have it out, the dimmer is the four wires on the right side in their own connector. Hope this helps.
-Joe-
98 Explorer (Lemon Law Case in Progress)
'00 F-150, X-cab, 4x4, Lariat, Off-road, Trailer Tow, Holandia Sunroof, built 11/99 picked up 10/00!Clear Corners, Manik Stainless Steel 1-piece brush guard, Custom CB wiring, Uniden PC76-XLW CB radio with K-40 Magna-Mount antenna (for now), 1 set of 165 watt KC Daylighters (for now... more on the way) Custom switch mounting plate and overhead console.
List of planned mods: Clear tails, color matched trailer hitch with stainless steel ball, torsion bar tweak, bug deflector, spray in liner, and a tonneau of some sort...
93 Probe GT teal, OE rims painted to match, bone stock drivetrain.
Old Dec 17, 2000 | 03:02 PM
Cpt1's Avatar
Post
Thanks a bunch for the help!
Im gonna give it a shot this afternoon
Cpt
Old Dec 20, 2000 | 09:25 PM
LoweredFord's Avatar
Post
Hey dude sweet truck, what size neptunes are those and who did your drop for you air or juice? How far did you body drop it? Thanks for any info going to do mine in a couple months I have 17 x 9.5 neptunes wanting to know if they would tuck...........email me at loweredfordf150@netscape.net
Old Dec 20, 2000 | 10:24 PM
GIJoeCam's Avatar
Post
Doesn't that defeat the whole purpose of buying a truck in the first place? Wouldn't clear the pot-holes around here, let alone the curbs, driveways, small furry rodents that dart out, small children that dart out, hondas, acuras, mitsus and other assorted imports that get in the way. :-)
Looks nice, though.... Did you have to modify the fender wells or the bed to get the clearance for the axle and suspension?
-Joe-
[This message has been edited by GIJoeCam (edited 12-21-2000).]
Old Dec 20, 2000 | 10:30 PM
ThePyroManiacKid's Avatar
Post
hey Cpt1
that truck is sweet
i loved airbagged trucks
actually i am in the process of trying to convince my dad to let me put them on
what brand did you use and how did it cost?
do you know any sites that i can look into this about
thanx
1999 F-150 Supercab Styleside Lariat 5.4L V8 3.55 gears, Rhino Bedliner
lowered 2/3, 18inch Wheels, Navigator Front End, Factory 2tone Red on top of Gold, Metallic Flake Ghost Flames in the gold
Stock CD player, Rockford Fosgate Punch 250a Amplifier, 2 RF Punch DXL 8inch Subwoofers, 2 Kenwood Midranges in the front doors
By Christmas: Euro tail lights, Superchip, 3/5 drop
By my 17th birthday (March 23rd): White Face Guages, HOPEFULLY A SUPERCHARGER PACKAGE
some quick photos
www.geocities.com/thepyromaniackid
Old Dec 25, 2000 | 03:51 PM
Cpt1's Avatar
Post
The rims r 20 by 8.5. Totally Polished in So. Cali did the bags and body drop (3 and 3/4 inches.) The 17s should tuck pretty easy, as long as u got the ones with lots of offset. Also assuming you got the fwd version, u should find the thinest adapters out there. Mine are 1 inch
I no longer have fenderwells, u open the hood and the tires r right there,, i also jad to modify the firewall to get them to fit. For the axle i hae a whole in the bed floor for the axle and notch to come through. Im gonna take some sheetmetal and cover it up soon tho. It will just be raised in that section.
I used firestone bags,, pretty much every1 uses them. SMC valves. U can usually get them installed for around 2-3g's including the kit. It all depends on how fast u want to go.
Cpt
Old Dec 30, 2000 | 04:05 PM
Post
Cpt1,
Thanks for the info, your truck is very sharp, I have the truck syle neptunes but I think they will tuck but it will be close, thanks again for the info, i have a buddy just opened a shop so i can get all the air ride stuff at cost..................
Old Dec 30, 2000 | 11:18 PM
Turtle9343's Avatar
Post
I am not sure what type or year your truck is but here is how to get the headlight switch off in my 97. You have to turn the headlight switch both ways a certain number of degrees and it will pop right off. I know it is vague but if it you still havent figured it out let me know and I will get the exact directions from my repair manual and get back to you.
Old Jan 3, 2001 | 03:49 PM
blackfordF150's Avatar
Red face
<font face="Verdana, Arial" size="2">Originally posted by GIJoeCam:
-Joe-
</font>
Well I have a 96 ford Explorer that I have been having lots of problems with I recently had an accident in it and the air bag did not diployed I dont know why since the impact was pretty hard, You are talking about a lemon law can you tell me more about it.
Old Jan 3, 2001 | 07:28 PM
GIJoeCam's Avatar
Post
I'd be happy to tell you everything I know... sounds like you have a different situation, though. E-mail me at gijoecam@prodigy.net with some questions, and some details about the accident. In the mean time, check out this site:
www.lemonaid.com
He's the attorney I used, but as far as I know he only practices in MI. I believe there is info there on other states' laws, and I believe he can refer you to someone in your area.
As for other Explorer issues, go to this site... www.4x4central.com
It's got tons of info for Explorers and Rangers, like this one does for F-150s and Expeditions.
Talk to you soon.
-Joe-
