Shorter Replacement Antenna?
https://www.f150online.com/galleries...3374-thumb.jpg
This is mine. Found it searching on the web. I also used a Navigator Chrome base cap, too.
Got a Shorty Antenna. They offer them in a variety of colors and lengths (I'm using a 6" chrome antenna). The mast is thicker than stock, but all metal. They offer adapers for most domestic trucks including the F-150. The good thing is that mine fit exactly like a factory part. Zero problems, and I nolonger need to reach when putting on the car cover.
I just tried to perform the "ball-pop-off" method, but I was unsuccessful in getting the damn little thing off. Is there some trick to getting the ball to come off the top of the antenna?
-Craig
-Craig
All I did was use a pair of locking pliers with a cloth to help protect the black paint, and slowly twisted it back and forth. It came off pretty easily.
Once I cut the rod down, I put a dab of super glue on the end of it and put the ball back on the same way. I also had to lightly run a file across the end to get the ball back on.
I did notice that my cloth only minimized the amount of scraping on the ball, but I just used a little bit of black vehicle touch up paint that I happened to have, to touch up the ball.
I finally figured it out yesterday. I ended up having a friend hold the antenna while I put the forked end of a crowbar over the ball and hit it with ha hammer. It was kinda like killing birds with a bazooka, but hey, at least it worked!
-Craig
-Craig
trimmed mine last night, couldn't get enough leverage with my wire cutters, so i used vice-grips at the point i wanted it cut, and took the hacksaw to it.
came off quick, little touchup paint. didn't put the ball back on yet. gonna watch it at highway speeds and see if it's effected at all.
