Need some Amp help
Old Nov 23, 2012 | 11:07 AM
  #31
hercules.'s Avatar
I am piecing together parts for my system install in my extended cab. I wanted an stealth system so here is what I have so far:
Shaker 500 and KENWOOD EXCELON KFC-X683C 6x8" SPEAKERS/ speaker harnesses on the way.
Here are the specs on the speakers
Quote:
2-way 6x8" custom fit speakers (it will also fit in a 5x7" opennings)
180 watts peak power
2-60 watts RMS power
Diamond Array Pattern carbon-polypropylene woofer
Butyl Rubber Surround
1-3/16" PEI balanced dome tweeter
4-ohm impedance
Frequency response: 80-21000 Hz
Sensitivity: 88 dB
Custom fit to select FORD & MAZDA vehicles
Mounting depth: 2-9/16"
Screws (8 pcs) and speaker wires (2 x 11") are included
The speakers don't come with a grilles
I am going to get a JL Cleansweep from Crutchfield (for warranty and install info) and then a sub/ box and amp.
I am thinking of going with this
10" kicker sub with box
Thoughts on it? I listen to mostly country, but occasionally some rock and a little pop/rap in there. WOuld that be ample? I am unsure on how to pair the system to an amp. I am looking to amp my front speakers and the sub obviously. What would be a good budget friendly amp to safely power the system? Also, would it be worth putting 2 10's in the back like this or is that overkill?
I only want to have one amp for the whole system so I know I would need a 4 channel for sub and front speakers. If I did 2 10's would I need a 5 channel?
I appreciate advice here,
Thanks,
John
their is no such thing as overkill i run a 600 amp alternator three batteries 3 farad cap 4 kicker comps. 2 ro kford 1200s and a ro kford 500x4. go big or go home buddy dp ur thing. oh yeah and my truck isnt extended and ita still very comfortable
Posted from F150online.com App for Android
Old Nov 23, 2012 | 11:30 AM
  #32
pizzaman711's Avatar
600 amp single alt? Who makes that?
Old Nov 24, 2012 | 09:14 AM
  #33
hercules.'s Avatar
I started with two tens Pb and a single 11oo cheap amp with no upgrades anywhere and as far as rock music and country they have better SQ then my current setup sounded great,
Old Nov 24, 2012 | 09:17 AM
  #34
hercules.'s Avatar
Stinger makes them High priced little suckers to.
And to add i was going to give u a link for them but apprently they do not make them anymore bout the highest u can get is 400 untill u go up into the dual setups and custom brackets
Old Dec 11, 2012 | 10:45 PM
  #35
Ok guys more update...
here's the sub I got... 39.99 on Black friday so I thought it would suite my needs fine:
http://www.sonicelectronix.com/item_...C-W2513PS.html
I'll be making a full blown custom center console that will also house this sub. In terms of installing my 5 channel amp and wiring the speakers and sub, what do I need? I'd like to install the amp and get the speakers amped over my winter break if possible the week I get out of school since I have a small lull in work hours. Any help would be appreciated... I'm new to this stuff
Old Dec 14, 2012 | 08:57 AM
  #36
Bump
Old Dec 17, 2012 | 12:47 AM
  #37
K.R.newbie's Avatar
will that woofer fit your setup???? thought you needed a shallow depth woofer for under the seat????
Old Dec 17, 2012 | 12:48 AM
  #38
K.R.newbie's Avatar
guess it will!!!!!!
Old Dec 21, 2012 | 01:31 PM
  #39
Yeah it should be fine, it's near shallow mount, which is what I need
