Remote Wire Question?
Old Dec 28, 2009 | 02:12 PM
marcus1033's Avatar
I have the Pioneer 3100 DVD. I did the DVD bypass using a Bosh relay, which involves using the remote wire off the H/U. Can I still splice into the remote wire for the amp remote turn on. Also when I add my second amp down the road, can I splice into the remote turn on wire at the amp board for the second amp?
Old Dec 28, 2009 | 10:05 PM
Sundevil2188's Avatar
yes and yes.
kuruption's Avatar
Yes, though you may want to use a relay for that, too. In other words, remote wire activates relay that provides power directly from the battery.
Old Jan 3, 2010 | 05:54 AM
phattacorider's Avatar
Your best bet would be to use a relay. I'm sure you won't encounter any problems running your bypass and two amps on the REM+, but I personally wouldn't chance it.
Old Jan 3, 2010 | 09:35 PM
codywilliams45's Avatar
quick question for you guys. i put a dual xdvd9131 headunit it my 03' and for some odd reason it doesnt have a remote turn on wire. i dont know much about stereos but what else could i hook my amps remote turn on to? thanks
Old Jan 3, 2010 | 09:55 PM
JJDH's Avatar
yes it does. its the blue/white wire
http://www.dualav.com/support/manuals/xdvdn9131.pdf
Old Jan 4, 2010 | 12:27 AM
i know it says that in my manual but there isnt a blue and white wire coming out of the back of the hu
Old Jan 4, 2010 | 02:46 AM
The only other option you have is splicing a wire in to your ignition wire (or the red wire) and connecting that to the amplifier. The suggestion for that would be to use a relay.
Old Jan 4, 2010 | 10:11 AM
alright well thanks for the help
