Power wire for amp.
Old Apr 9, 2009 | 12:24 PM
poo_'s Avatar
Originally Posted by mSaLL150
There is a grommet right behind the battery into the cab. Pulling the battery makes it a lot easier to access, and you dont need to run your wire across the engine bay.
Dammit, wish I would've seen this before
Old Apr 13, 2009 | 03:00 PM
LRG's Avatar
LRG
I would also add that if using the drivers side grommet note that it's fairly close to the exhaust so take measures to ensure that your cabling stays as far clear from it as possible.
Old Apr 29, 2009 | 10:23 PM
F150_xlt's Avatar
So my truck is going in tomorow to get a line converter put in, Im just getting them to do that and Im thinking about running my own power, RCA's and ground through my truck. Ive done it before in three different cars. But when i look at this truck its scary thinking about punching it through the firewall. So i was hoping to run my power wire down the passenger side, since iknow my power wire will be 2 short to run to the driver side. So is there an easy access point on t he driver side?? how hard is it to do, and did you guys have to take out the carpet or what? how did you run the wires through the truck without the wires showing? I was just hoping to run my wires underneath the plastic trim going down the side of the truck underneath the doors? does that work> Im kinda stuck and im gona be doing this tomorow i just dont wana **** my truck up at all..ANyways any help would be awesome like pics or anything, thanks
Old Apr 29, 2009 | 10:34 PM
JJDH's Avatar
here is a link. just search forum.https://www.f150online.com/forums/am...-wire-amp.html
Old Apr 29, 2009 | 11:27 PM
Justin_w32's Avatar
i found a grommet under the carpet on the passenger side on the floor i ran the power down through it and cut a hole in the rubber grommet to prevent chaffing and ran to the battery along frame rail and over the plastic piece of fender well. buts thats just what i opted to do, all the other options posted in this thread were very helpful as well
Old Apr 30, 2009 | 12:13 PM
F150_xlt's Avatar
Sweet im doin that this afternoon I hope it goes well..Im sure ill figure it out. Im gona check this grommet behind the battery, or hell i might just run it on the outside underneath the truck if i cant figure it out..I did find a big grommet i think its agrommet..Its like 3 inches tall and 6 wide, feels like thin rubber behind the cab passenger side on the back where the box lines up to(SUPERCAB) i dunno what it is, i think its for puttin something in there...I duno not sure tho..Dammit i cant wait to hear bass in my truck how do they sound in f-150's do they rattle alot? I have a 2400 watt premier amplifier, I got for dirt cheap there worth like 700 bucks, i got it for 300 at a store that was closin down..its the best amp ive ever had, and i have a alpine type R on it in car box bassworx, and a capacitor. I was just gona bolt the amp and capacitor on the box.Ya iknow icant afford a truck box right now so im just gona use this setup and put the box behind my drivers side. And its all hookin up to my stock deck i bought a 200 doller line out converter supposively the best you can get, so im hopin it sounds half decent.
Old May 3, 2009 | 07:07 PM
monoxide's Avatar
i just ran mine down the fender and in the grommet under the plastic diamond plate. lol. it ran fine under that and in the bundle of wires. you only see like a inch of the wire when it comes from the back trim panel to under the seat. where is every one running there grounds to?
Old May 3, 2009 | 07:25 PM
JJDH's Avatar
bolt grounds to floor behind back seat. sand paint to metal
Old May 3, 2009 | 07:32 PM
monoxide's Avatar
ok. hope fully ill get it all in today
Old May 5, 2009 | 02:49 AM
Justin_w32's Avatar
and if you dont will your amp still work? and if so will it blow fuses on the regular?
Old May 5, 2009 | 02:55 AM
Justin_w32's Avatar
does anyone know if i take out the fuse for the horn would the horn still go off when i disconnect the battery? i have to disconnect to hook up some stuff and dont want to **** my neigbors off too much lol
Old May 5, 2009 | 02:59 AM
JJDH's Avatar
no fuse no horn
Old May 5, 2009 | 03:01 AM
JJDH's Avatar
where ever u ground it the metal has to be bare. the cb floor, the backwall are both considered the chassis, also a weld point, so whatever is best for u . make sure it is clean and tight, the amp has to have a good ground, it is as important as the power wire
Old May 5, 2009 | 03:07 AM
Justin_w32's Avatar
no fuse no horn
Well thats what i figured but this is my first Ford, i hooked up a system for a buddy in a ranger and i almost hurt myself when i disconnected the battery and the horn started going off. He tells me after oh yeah the horn goes off when you disconnect the battery.
Old May 5, 2009 | 10:18 AM
pylda's Avatar
So you can create your own ground in the back wall or cab floor by inserting in a bolt/screw?
Does it need to be a certain type of screw or bolt? Obviously you would have to sand the surface down to bare metal first.
