Any reason for an amp up front ?
Old Oct 26, 2008 | 09:20 AM
FX4_2003's Avatar
I have a pioneer with 25 watts rms x4 ... I have an coustic amp bridged on 1 10" sub and still working on my bx to go under the seat in my 03 fx4 screw.. I have a front out on my pioneer HU also ( besides the one for the sub ) the only two amps I have other than the one I am using for the subs is a old Fast and Furious red amp 150.2 I think its like 35 watts rms X 2 and a Pioneer GX something or other that I believe is 30watts rms x 2.. Would there be a benifit to use an amp for the front if the HU already puts out almost that much wattage (Pioneer DEH 2900 MP ) I have Sony 3 ways in all four doors they are rated at 55 watts rms.. Keep in mind I am 42 years old and I am looking for Quality sound , I dont wont to blow the roof off my truck
If I do hook an amp up I am thinking the pioneer amp... I will get some pics...
Old Oct 26, 2008 | 02:31 PM
C. Whammy's Avatar
you might as well hook up the pioneer amp, since you have it
Old Oct 26, 2008 | 02:35 PM
azmidget91's Avatar
the amp should clean it up a bit
Old Oct 26, 2008 | 04:45 PM
1bad86vmax's Avatar
You can't compare a decks power to a external amps power . If you have a head unit that says RMS power to be 25wx2 and a external amp that says RMS power to be 25 wx2 . Most people would think that they would be even in output power , but the external amp will blow the headunit away all day long . Also keep in mind that all external amps (regardless of size) need to get power directly from the battery .
Old Oct 26, 2008 | 06:20 PM
nvrenufedge's Avatar
Also, having the amp will give you better control of the speakers. They will sound better and be able to play louder.
Old Oct 27, 2008 | 12:06 PM
1bad86vmax's Avatar
Dude , your head unit isn't putting out that much power . The amp in a headunit is about the size of a deck of cards . Please read below .
Car Stereo head unit power is VERY deceiving! Many head units have HUGE power ratings on the Boxes or right on the front of the units! The highest head unit power I have ever actually tested was 13 watts (at a half way decent THD)… So even if the head unit says 35Watts or 40 watts per channel on it don’t EVER expect for it to REALLY BE more than 15! Just cant happen!
REAL amplifiers use LARGE power supplies in them with transformers to STEP UP the voltage So that large amounts of power can be made! Head units just don’t have room in them For the large transformers that are needed for large power supplies!!!! So don't expect more than 15 watts per Speaker out of head units! Some of the more reputable head units might print high power ratings on the boxes but If you read the small print in the spec sheets in the owners manual they might admit to the 15 watt figure!
Old Oct 27, 2008 | 05:13 PM
FX4_2003's Avatar
General
Product Type Radio / CD / MP3 player
Recommended Use Car
Form Factor Full-DIN - in-dash unit
Width 17.8 cm
Depth 16.2 cm
Height 5 cm
Weight 1.3 kg
Faceplate Type Detachable
Audio System
Sound Output Mode Stereo
Sound Effects BBE, BMX (Bit Media eXpander)
Equaliser Yes
Display Controls Volume, treble, bass, fader, balance, loudness, midrange
Max Output Power / Channel Qty 50 Watts x 4
Continuous Power / Channel Qty 22 Watts x 4
Amplifier Output details 22 Watt - 4 Ohm - 50 - 15000 Hz - THD 5% - 4 channel(s)
Built-in Display LCD
Display Illumination Colour White
Button Backlight Colour Red
Features Telephone mute, CD Text capable, ID3 tags support
Equaliser
Equaliser Factory Presets Natural, Powerful, Custom, Vocal, Flat, dynamic
Radio
Type Radio tuner - AM/FM
Tuning Display LCD display
Preset Station Qty 18 preset stations
AM Preset Station Qty 6 preset stations
FM Preset Station Qty 12
Response Bandwidth 30 - 15000 Hz
Signal-To-Noise Ratio 75 dB
RDS Yes
Supported RDS Functions TP, AF, PI, PTY, TA
Additional Features Preset buttons, best stations memory, D4Q, DX/LO switch
CD System
Type CD / MP3 player
Form Factor In-dash unit
Media Load Type Slot-load
Playback Modes Intro scan, repeat folder, random play / shuffle, all tracks repeat, one track repeat
Supported Digital Audio Standards WAV, WMA, MP3
Response Bandwidth 5 - 20000 Hz
Signal-To-Noise Ratio 94 dB
Dynamic Range 92 dB
CD-R/CD-RW Compatible Yes
Old Oct 27, 2008 | 07:25 PM
mSaLL150's Avatar
Of course they are going to advertise that much power, they want you to buy their product.
Kind of like how companies like Hifonics and Boss say their amps produce huge power numbers upwards of 1000 RMS, yet when you look at their fuse ratings, capacitance, and their other guts you quickly realize its a complete joke and total bull****.
Old Oct 27, 2008 | 07:56 PM
1bad86vmax's Avatar
I'm not going to argue with you . If you want better sound , buy a good set of front coax speakers or better yet a component set , and a good external amplifier with rated output power to be anywhere from 30-75 watts RMS. You will be happy .
Old Oct 27, 2008 | 10:32 PM
FX4 2003, let me give you a word of advice. These guys know what they're talking about. Some of 'em do this for a living. If you're not gonna even consider thier advice, don't ask.
Old Oct 28, 2008 | 02:35 AM
Low_e_Red's Avatar
I would definately use an amp. You are running a lowend Pioneer (still decent) but the 18w that it truely can produce is nothing compared to the better dampening, better parts, and more true power with the amplifier.
Old Oct 28, 2008 | 10:23 AM
FX4_2003's Avatar
Just wondering when using OHMS law and using the wire size guage ( stuff I picked up in college ) do i size my amp wire by the rms power or by the companies max output rateing ?
Old Oct 28, 2008 | 11:57 AM
Low_e_Red's Avatar
What amp are you using?
Whos wire gauge charts? IASCA? MECA?
I always do RMS + 20%
Old Oct 28, 2008 | 01:27 PM
FX4_2003's Avatar
RMS + 20% got it .. Thanks for the input Red...
Old Oct 28, 2008 | 03:04 PM
FX4_2003's Avatar
http://www.youtube.com/watch?v=JVxbEOgufZ8
