Power cable pictures
Nope . The MTX 1501D requires a 1/0 guage power wire just for itself . The other 1/0 guage wire powers the remaining 2 amps , MTX crossover and Pioneer XM tuner .
.I had forgotten which amps you had exactly. I knew there was enough power on tap to send us back to the cold war, I just didnt look at the pics again.
Just do it the way, VMAX does his. If its good enough for him, its obviously right.
Theres a grommet almost all the way back on the pass side, thats the one!
Yes you can run it inside . The only reason people run it on the outside , is if your using 1/0 gauge or larger . It's kind of hard to hide wire that large under the carpet . Since your using 8 gauge , I would run it inside . How long is your run ? I'm not familiar with that amp , you might want to think about using 4 gauge .
That amplifier draws 60 amps of current . You would be fine with 8 gauge , as long as your run is only up to 7 feet . If it is over 7 feet(which it more than likely is) I would run 4 gauge . Why starve your amplifier of power ? Please see chart below .
This is my favorite basic guide to figuring out your wire.....
http://www.bcae1.com/images/swfs/sys...nassistant.swf
It actually makes it fun.
Anyone got pics of a 1/0 wire showing where to locate fuseblock then how it goes from fuseblock to belly of truck to the point where you are routing yours to the passenger grommet?
