System Complete...Pictures
Originally Posted by DRJ
I like how you took the time to trim the insulation crap outta the way around your 400.4 instead of just putting it on top of it
yeah, i like that too, can you briefly explain how that amp is installed there? gathering install ideas.
Once the rear seat is removed (pain in the ***), you can pop off the gray panel. It's just held on by plastic plugs. Next I cut a panel slightly bigger than the amp and used self tapping screws to attach it to the metal back panel of the truck. I used a piece of brushed aluminum but you can use plywood. After everything was plugged in and working properly I measured and cut out the gray panel so it would leave the amp exposed. Re-assemble and thats it.
By the way, I ran my RCAs and speaker wire under the carpet down the middle of the truck and power wire from the battery down the side under the sill plates.
