tri mode amps to power 4 ohm co-ax and 8 ohm sub?
Hey, so I have to buy a new amp for my sub because the old one is shot.
The sub is a JL 12w1 at 8 ohms. I also have a set of 6x9's in boxes that I use when tailgating. Previously I had run one amp for my sub and one amp for my 6x9s.
Can I use a tri-mode 4 ch amp to power all of these? ie. bridge 2 channels for the sub and then use 2 channels for the 6x9s when I tailgate? I'm not sure if you can mix impedence on the same amp like that.
Thanks!
Thanks!
Thanks!
Thanks!
On impedance: realize the impedance looking back in toward the amp is very, very small - fractions of an ohm. So as long as you do not exceed the specs on loading, yer good. Folks fret way to much about impedance, IMHO....
bubba
Originally Posted by MGDfan
Sure - they're separate discrete output stages.
bubba
bubba
This also makes it so that I can buy another sub amp at some point. Then I'd use the 4 channel for the regular speakers and just put a switch to change from the door speakers to the 6x9s for tailgating. Leaving the sub on it's own amp.
