Grounding in a single cab?
Old Apr 16, 2006 | 01:52 PM
TXhustla's Avatar
I have a 04(heritage) & my amp is under drivers seat where is the best spot?
Old Apr 16, 2006 | 02:24 PM
RagePro's Avatar
Ground it to the seat bolt. If you are not certain use an ohmeter to check resistance to known ground. You may need to scrape the coating off the bolt and the seat rail too.
Old Apr 16, 2006 | 11:29 PM
nothinbutaford's Avatar
Never trust a seat bolt for ground see the "noise" thread in the "other audio category" Scrape the paint off a solid metal surface and use a screw or nut and bolt if you can get to the underside.
Old Apr 17, 2006 | 02:26 AM
TXhustla's Avatar
Right now its to the left of the pedals. In a single cab there isnt much room to ground. Its either keep it where its at, drill(really dont want to do) or use one of the seat bolts. Also where can you buy an ohmeter and how much does it cost?
Old Apr 17, 2006 | 09:54 AM
RagePro's Avatar
You can get a multimeter (voltmeter, ohmeter etc) at radioshack, home depot, lowes, pep boys, etc...
As nothingbutaford pointed out, you may experience some ground loop issues with the seat bolt. If you don't want to drill another hole and you do have noise on the seat bolt, you can get a ground loop isolator for $10 or so at any electronics store. Drill the hole if you can.
Old Apr 17, 2006 | 08:39 PM
GA FOO 88's Avatar
I grounded mine where those plastic screws are in holes in the frame under the carpet by the drivers seat, and ran a nut bolt through it with the ground wire. Then ran the ground wire under the plastic paneling that pops off, and covers the edge of the carpet and door.
Old Apr 17, 2006 | 08:51 PM
Not only may you end up with a ground loop problem, you can damage the preamp of the radio. If the amp can't find a good ground with the wire intended for it, it will find a ground through the path of least resistance=ground of the preamp. If your amp draws enough current through the preamp all the smoke will come out.
Old Apr 17, 2006 | 09:09 PM
TXhustla's Avatar
I going to do exactly what you said. Local shop told me that is the best way.
Old Apr 17, 2006 | 09:13 PM
bigrobrn's Avatar
I've got both of my amps grounded to the seat bolts. One to the drivers side right rear bolt and one to the drivers side left rear bolt. Was sure to take an air tool type paint removing tool and remove all paint to a nice shiny surface. I placed the solid brass terminal directly on the surface of the metal floor and then placed the seat right on top, then the bolt through the seat to secure.
I don't have any noise. At least that I can hear.
Do I need to make any changes???
I also have my some of my rca's ran next to both of my 8 gauge power wires. They are heavy shielded from KnuKonceptz.
Do I need to make any changes to that?
Old Apr 17, 2006 | 10:35 PM
Bartak1's Avatar
Bigrobrn, if your not having any problems, I probably wouldnt worry about it.
Old Apr 18, 2006 | 06:16 AM
styxnpicks's Avatar
the seat bolts are badass grounding point if you remove the paint
Old Apr 18, 2006 | 10:23 AM
bigrobrn's Avatar
I'm just making sure. I dont mind drilling a new hole somewhere hidden if it will improve something.
No problems as of now that I can see.
Old Apr 18, 2006 | 11:15 AM
sether's Avatar
I did the same thing and haven't had any problems at all.
Old Apr 18, 2006 | 12:18 PM
TXhustla's Avatar
Is it better to have a longer gauge or shorter?
Old Apr 18, 2006 | 05:28 PM
styxnpicks's Avatar
highest gauge, shortest length possible
