Air compressor mounting location
Old Apr 12, 2016 | 03:43 PM
Eric Finley's Avatar
Hi i have 2015 supercrew 3.5 ecoboost 157 wb i just purchased the air lift wireless compressor with firestone bags has anyone installed this setup yet im having trouble finding a place to mount the compressor under the hood is not possible was thinking in the bed under my tonneau but dont want to punch holes through the bed for the air lines any suggestions
Old Apr 12, 2016 | 08:29 PM
Scott91370's Avatar
I put mine on the frame just after the cab in the driver's side. They say it's water proof, we'll see.
Old Apr 12, 2016 | 08:39 PM
I was thinking of putting it inside a small toolbox then mounting the box to the frame i live in michigan winter time salt sucks just trying to protect my investment
Old Apr 12, 2016 | 08:59 PM
Scott91370's Avatar
I was trying to think of a way to protect it as well. That should work. Maybe I'll look for a box now!
Old Apr 13, 2016 | 09:04 AM
WoodsTruck's Avatar
Would a heavy gauge plastic or fiberglass type box work? Seems there are some made for irrigation controls that are subject to the elements that might be about the right size and designed to be waterproof and resist the salt.
Old Apr 13, 2016 | 09:21 AM
Scott91370's Avatar
That would probably work better than metal since it won't rust. Put a small hole in the bottom for any water/condensation to drip out.
Old Apr 13, 2016 | 02:21 PM
Was definitely going to use plastic found a craftsman that is 13x5x5 and pretty thick material i measured the outside of frame on pass side it will fit and still be able to open for maintenance just have to find time the bags should be here tomorrow according to ups im gonna tackle it tomorrow ill post some pics
Old Apr 14, 2016 | 10:13 AM
What ive done so far have to go to autozone to get a micro fuse tap the 2 taps that airlift sends won't work on the micro fuses
Old Apr 14, 2016 | 08:01 PM
Scott91370's Avatar
Nice! Now for another project.
Old Apr 14, 2016 | 10:29 PM
This is a pita cant figure out how to run the wires up to the fuse box theres no hole in the firewall
Old Apr 14, 2016 | 10:31 PM
Scott91370's Avatar
I cut the wire ties off the grommet just under the brake booster and ran them through there. It is tight and has a slight bend in it so it took two of us. One inside the cab to push the fish tape through and me on the outside to help guide it.
Once ran I put new ties on.
Old Apr 14, 2016 | 10:36 PM
I already ran the wires up the pass side because the fuse box is on that side theres a empty grommet at the bottom of the firewall i shoved the wires theough probably 2ft worth and cant find it on the inside im stumped and beat been at this for 5 hrs now
Old Apr 15, 2016 | 01:15 PM
Install complete found a grommet on pass side where power running boards wires go through
Mounted custom compressor box above rear axle on crossmember
