5.0 and Towing ?
5.0 and Towing ?
Who has towed what with a 4x4 5.0 and how did it do. And to open a can of worms. Please no war, Has anyone towed the same with an 3.5 eco then a 5.0 and a comparison.My 13 eco tows our 24 foot loaded toy hauler great but ,how would a 5.0 compare. We are looking at a 2015 5.0 So, how does a 5.0 tow and what have you towed?
I think your question the way it is asked not many members have had the opportunity to drive the load with the 5.0 and 3.5. So how could anybody answer.
I just purchased a 3.5 eco and had a 5.4 . Have not towed with it yet. This weekend. I cant reply to your post as I did not have the motors you want information on.
Try rewording your question and see what you get.
I've towed with my 14 5.0 several times and it runs great. From my experience the truck with downshift once or twice on a hill depending on speed and how tight you want to maintain speed.
I've usually get about 10.5 to 11.5 loaded up
Pat man thanks,what have you towed Bekool2323 ,I thought I had asked it both ways how does a 5.0 tow and has anyone towed with both. thanks I changed it. I have had more then my share of problems with our 13 eco and I really want to stick with ford I know there is no way all eco's have the problems I've had, i'm going to get rid of the 13 but i'm very gun shy on the eco
What problems have you been having with it?
If I was to get a 5.0 and planned on towing much I would get the steepest gears possible. That engine needs to rev to make its best power. The tighter gears would really help it out.
I have a 3 place enclosed sled trailer. Had a trip to Idaho with 3 sleds and 3 people. '12 5.0 Supercrew 6.5' 3.73 gears 4x4. Towed the trailer very well and pulled just about every hill at 70 mph with room to spare. I averaged 10 mpg over 1000 miles.
I have absolutely no experience with the EB line of motors in the trucks so I can't compare, but I am pleased with how this 5.0 pulls. In fact I will likely be upgrading to a larger trailer so I can pull 4 sleds (5 sometimes) and the 5.0 will likely pull it decently as well.
You may want to look at the HD Payload package with the 5.0 as it gets the 3.73 gears and increased payload. The towing capacity in a Supercrew with Maxtow (requires Eco) is within approximately 100 lbs of the HD Payload and tow package with 5.0 combination. There is not going to be a trailer that one can pull that the other cannot, but the 5.0 will have to rev a little higher to get into peak torque. One of the disadvantages of the HD Payload package is you are unable to order the higher end trim packages. If you are towing a lot at altitude (or racing a Chevy or Dodge while towing) you will probably appreciate the Eco but you will be giving up that pleasant rumble of the 5.0 on a daily basis.
I have towed numerous times with our 13 5.0 Supercrew. I previously had a 90 460. The 5.0 does very well. It makes blistering power in higher rpms, but it has plenty down low too. I towed a 32' travel trailer, pulled a Ford Probe on a heavy trailer, pulled a 14' stock trailer twice, pulled a 10' cargo trailer once on 200 mile round trip, and a 12' UHAUL twice on the same trip. My worst towing mileage was 12.3 with 32' trailer. The truck has thankfully been trouble free for over 65,000 miles.
Is the reason this is even a question because the F-150 is "punching above its weight" and taking on towing jobs normally reserved for SuperDuty trucks (and the good ol' 6.2L V8)?
Everything I've seen online (marketing) for their towing capacity, shows the 3.5L-EB w/ the 3.7 gear ratio pulling ridiculous loads, at ridiculous speeds. I plan to have a modest camper trailer with my 3.5 gear ratio and 3.5L-EB. Am I kidding myself? What's the largest weight trailer-hitched load you guys would risk on this truck?
The limiting factor with these trucks is not the lack of power or really even the brakes. It's the size of the truck itself. A really heavy trailer will push the truck around. A EB with 3.55s is factory rated around 10k with the limit being tongue weight and truck payload. I wouldn't have a problem pulling the max with my truck. Much more than that (ignoring DOT) is doable but starting really should be done with a larger truck.
