15 f150 rear end gear/ engine questions
Old 05-10-2015, 07:34 AM
courtesy's Avatar
hello to all
i was wondering which gears would work better with what motor i ordered a 15 screw plat 3.5eb bombed out with the 330's to be honest i didn't pay much attention to the gear as i have a 14 super duty diesel screw plat that i use for heavy hauling again i am looking for info on the 3 engine and gear combo thanks in advanced
Old 05-10-2015, 09:01 AM
WoodsTruck's Avatar
Are you planning to change tire sizes?
Old 05-10-2015, 09:00 PM
courtesy's Avatar
no keep original 20's
Old 05-10-2015, 10:03 PM
glc is offline
So, what do you mean "work better"? A vague question only gets a vague answer.............
Old 05-11-2015, 06:41 AM
courtesy's Avatar
sorry what would have been the difference between 330 and say 355 with the 3.5 eb
Old 05-11-2015, 09:50 AM
Wookie's Avatar
The 3.31s behind an 3.5EB will be perfectly fine. The biggest benefit the steeper gears is if you want to pull something really heavy or put on marginally larger tires. You have a diesel so if you're gonna pull something really big use it.
Quick Reply: 15 f150 rear end gear/ engine questions
