Hard start
Old Nov 28, 2021 | 07:01 PM
Mcmanama01's Avatar
Hard start
I have a 09 f150 platinum with the 5.4. For the last couple days when it’s cold outside the truck will not start. Once it warms up it will start and run fine till it’s sits overnight. I have 55lbs of pressure at the fuel rail. I have no codes and the fuel pump driver module is new. Also the fuse pump fuse has already be relocated. I’m lost now. Any advice would be greatly appreciated.
Old Nov 28, 2021 | 07:46 PM
When you mean it doesn't start, does it crank (engine turn)?
Old Nov 28, 2021 | 07:49 PM
Mcmanama01's Avatar
it will turn over but not start
Old Nov 28, 2021 | 07:52 PM
I would say have the battery tested at this point.
It might be the fuel pump, but a battery test is free.
Old Nov 28, 2021 | 08:09 PM
Mcmanama01's Avatar
Battery is new
Old Nov 28, 2021 | 08:10 PM
Ok. Let's see what other folks come up with. Maybe I'm forgetting something to check on those '09 trucks.
Old Nov 28, 2021 | 09:23 PM
Try cleaning the throttle body, watch this video:
Old Dec 5, 2021 | 02:28 PM
Mcmanama01's Avatar
Ok so I have cleaned the throttle body. I had a shop look at the truck. They suggested a fuel pump. So new fuel pump. New fuel pump driver module. And still having this issue.
Old Dec 5, 2021 | 02:58 PM
I think at this point, you will need to go to a shop that has a computerized scan tool, and someone that can sit down and compare values from the service manual. It's a tedious job, but in your case, without throwing parts at it, is the best way.
Old Dec 5, 2021 | 04:19 PM
Mcmanama01's Avatar
I just got it out of the shop. They hook it up to a scan tool and I was told all the values were correct on everything else. Then it died on me on the way home from work. Now it will run for a few mins and shut off.
Old Dec 5, 2021 | 05:22 PM
When they replaced the fuel pump, did they replace the fuel filter?
Old Dec 5, 2021 | 06:20 PM
Mcmanama01's Avatar
It doesn’t have a inline filter. Just the one on the fuel pump it’s self
Old Dec 5, 2021 | 08:10 PM
That's what I asked. Did they replace it? Fuel pump does not come with one, it's a separate part.
Old Dec 5, 2021 | 08:16 PM
gDMJoe's Avatar
Post
-deleted-
Old Dec 5, 2021 | 08:24 PM
Mcmanama01's Avatar
According to the paper work they did replace it.
