Power steering help
Old Nov 12, 2019 | 11:17 AM
Timothy Fahl's Avatar
Power steering help
I started my 2010 F-150 5.4L this morning (first freeze of the season) and my power steering return line blew off the top of my condenser. I recently changed my condenser (3 months ago) and thought maybe i did a poor job reattaching the line, so i put the hose back on and clamped it, then restarted my truck and after running for a few minutes to warm up, the same line busted. And continued to spray out the power steering fluid. Before i put a new line on Im concerned that there is an issue causing pressure to build on that line, because to my knowledge there shouldnt be that much pressure in that line. Thanks for any help
Old Nov 12, 2019 | 04:43 PM
Condenser? You mean cooler? Maybe it has a blockage.
Old Nov 19, 2019 | 07:57 PM
Greg Moore's Avatar
There is pressure there, nothing like the high pressure side coming out of the pump, but even the returning oil is under some pressure. When cold, the oil is thicker and causes higher pressure. Is the line you put on there factory or just a common hose? While it doesn't need high pressure crimps, it does need to be at least fabric reinforced and clamped properly or it will let go.
