Replacement Exhaust
Old Oct 24, 2019 | 10:13 AM
Du4's Avatar
Du4
Replacement Exhaust
Morning all. I would like to just replace my factory exhaust with something a little more beefy. I have a 2013 Ford F150 XLT 5.0. I'm trying not to have to re-do the whole exhaust system.....just the main exhaust. Any suggestions?
Thanks in advance for your help.
Old Oct 24, 2019 | 10:33 AM
Easiest thing to do is delete the resonator. The stock muffler is low restriction.
Old Oct 24, 2019 | 02:46 PM
gDMJoe's Avatar
Lightbulb
glc - Easiest thing to do is delete the resonator. The stock muffler is low restriction.
The resonator is also straight-thru, low restriction.
Du4 ... little more beefy...
Rather replacing the entire exhaust system, would recommend replacing the stock muffler with an after-market, stainless steel performance alternative.
Unless you seriously mod' the engine, there is little to be gained HP-wise and/or MPG-wise in altering the exhaust. Do it for looks, do it for sound, do it for anything else and you're wasting $$$$$.
Old Oct 24, 2019 | 04:53 PM
I was simply referring to the easiest way to get some more sound, assuming that the system does not NEED to be replaced for any other reason.
Old Nov 19, 2019 | 08:40 PM
tbear853's Avatar
https://legatoperformance.com/collec...t-cat-back-kit
Old Dec 12, 2019 | 10:27 AM
thebossross's Avatar
I've heard a lot of good things about the flowmaster outlaw and outlaw extreme, the outlaw will run you around 700-800 with the single into dual system. the extreme dumps under the bed and will cost you around 350 or so. both are easy to install cat back systems, I plan on putting the dual outlaw on my 2010 5.4 here in a bit
