eng coolant
Mherring - highway speed 70 to 75 IM seeing temps around 217 to 220 sometimes up to 222.even when pulling a load im seeing same temps. any tips or additives to possible get it running cooler
- How's the coolant level?
- Mileage?
- When was the last time that debris was cleared/cleaned from the radiator and trans' cooler?
- How's the oil level? and ... What weight is being used?
- What, if any, mod's have been done to the vehicle?
*FTR (For The Record) - The themostat opens at 95°F+- and the cooling fan(s) should kick-on at 215°F+-
glc - Joe, there's enough info - 2011 with 3.5, which is Ecoboost.
More betterer to provide it upfront than playing 20 questions.
As glc told you, your coolant temperature is fine - it's "normal" in fact. You DO NOT want it to run cooler. In this case, cooler is not better.
- Jack
- Jack
