2013 F150 won't start, most electrical working
Hi everyone! Just joined this site and hoping someone can give me some advice. I've searched as much as I could, but can't seem to find my exact issues and a solution for them.
I have a 2013 F150 (115,XXX mi, lariat, 2wd, if that matters) that currently won't start. Just a couple days ago, it died when I turned the wheel all the way to the left leaving a parking space. Started right back up with no hesitation. Got it home, and when I tried to unlock it an hour or so later with the key fob, it wouldn't. Didn't think much of it and unlocked manually. They anti-theft started counting down, I stuck the key in to start it, and nothing.... great, alarm starts going off with nothing I can do about it. After about 20 seconds, it seemed it had enough juice for me to hit the unblock button on the key fob to turn off the alarm. Tried to start again, nothing (doesn't even make a sound like it's trying). So at this point: key fob doesn't work, truck won't start, rest of electrical seems fine.
I pop the hood to look for anything obvious, but don't see anything. Battery terminals have some corrosion, so I get some baking soda solution and clean them. Try to start again, nothing. I then take off the connections to the battery to try to reset everything. Try key fob, and it works. Try to start truck, and it starts! I get in ready to leave, and notice that the ac/heat are not coming on, the outside temperature shows "--" on the display, and I do not hear the cooling fans kicking on in their typically annoying fashion. I don't think much of this because these symptoms happened once before during hurricane Harvey. That time, the problem resolved itself after a few days of dry weather (we just had several days of rain last week). I did run it by my mechanic anyway that time who said it may have just been some moisture that seeped in somewhere and caused the issues.
I've given it a few days, it was still starting but with no ac/ heat, key fob not working, temperature not displaying, and fans not kicking on. Everything else is like normal. Today more of the same, but it did die on me at a stop light - turned right back on. Drove a couple more times then stopped at a friend's place, got to leaving, but my truck wouldn't start again.
Tried disconnecting battery again, nothing. Checked all the fuses mentioned in this and every forum on the internet - nothing. Left to get my jumper cables, came back about try 40 minutes later. Tried again, and the anti- theft alarm went off. Thought it was a good sign, disconnected/reconnected battery, then nothing. Tried jumping, nothing - doesn't even sound like it was trying. Pre-jump, it did sound like a little clicking from the passenger area fuse box. During the jump, nothing.
From other forums, I'm leaning towards: corroded cables, fried starter relay, dead starter. Battery is only a year or so old, and tested at 60% when I put it on a charger. Also, all the other electrical works as normal, so don't think it's the battery.
Help! Any suggestions before I start spending money on needless items, lol? I took out the relay in the number 2 slot but not sure if it's something O'Reilly's/Advanced/Auto Zone can test. Was just going to buy a new one and try.
Thanks. Both fuse boxes are clean and dry.
I've taken the starter off (pain in the butt), and had it bench tested at O'Rielly's and Auto Zone - tested bad. Just picked up a new one. I'll install and update tomorrow.
a41schneider - Im curious what happened just the starter issue ?
