Stubby Antenna
Old Oct 28, 2017 | 07:26 PM
RoosterJCogburn's Avatar
Stubby Antenna
Howdy Y'all
First Question from FNG. Any recommendations on the best stubby antenna? Sound quality/reception distance?
Much appreciated.
Old Oct 29, 2017 | 08:10 AM
projectSHO89's Avatar
The "best" antenna isn't going to be a stubby antenna. Shortening the antenna reduces its efficiency which translates into reduced reception range.
Old Oct 29, 2017 | 01:29 PM
gDMJoe's Avatar
Arrow
projectSHO89 - The "best" antenna isn't going to be a stubby antenna. Shortening the antenna reduces its efficiency which translates into reduced reception range.
+1
And ... If you opt for a shorter (non-stubby) antenna you're more than likely going to experience wind-whistling at highway speeds. *Personal experience.
Old Oct 30, 2017 | 09:38 PM
Originally Posted by gDMJoe
+1
Yup! I have a shorter than stock antenna and the whistle is certainly there. I put the oem on when doing a roadtrip if i can remember. Otherwise i remember about 10 miles into the trip
Old Nov 6, 2017 | 05:51 PM
I am running this one on my 2013 F-150 and like it. The 4" black version.
https://www.amazon.com/MADE-USA-2009-2018-Aluminum-Antenna/dp/B01M750LH4/ref=sr_1_2_sspa?ie=UTF8&qid=1510008571&sr=8-2-spons&keywords=f150+antenna&psc=1 https://www.amazon.com/MADE-USA-2009-2018-Aluminum-Antenna/dp/B01M750LH4/ref=sr_1_2_sspa?ie=UTF8&qid=1510008571&sr=8-2-spons&keywords=f150+antenna&psc=1
It still has ok reception on the stronger stations in my area. But I don't care about the loss. Hardly drive the truck, and I only wanted it to reduce damages from garage door. I would post a photo, but you know photobucket and wanting $400 for 3rd party sharing lol.
It's quality however is very nice. I had the ever famous one called "The Stubby" which was a cheap plastic one on my 2007, a car wash destroyed it.
Old Nov 6, 2017 | 06:15 PM
You don't need Photobucket, you can now upload pics directly from your hard drive. Hit the image icon and browse device.
Old Nov 6, 2017 | 09:09 PM
RUSS04's Avatar
My antenna hit when i pulled into the garage. I think i saw something on this site to fix the problem. What i did is measured the antenna to clear the garage door opening,i then cut the antenna and drilled out the ball and glued the ball back onto the antenna. I did that 13 years ago and no problems with reception. The ball is still solid today.
Old Nov 7, 2017 | 10:59 AM
mossbum's Avatar
I use a stubby from craven speed. Reception is reduced, but I also think it looks better and it doesn't slap my garage anymore.
Old Nov 7, 2017 | 07:16 PM
Now I remember why I installed a 9' high garage door in my new garage.
