'12 FX4 rear diff fluid?
Old Mar 22, 2016 | 05:21 PM
johnstonblake's Avatar
What do I need to order to change the rear diff fluid on my 2012 FX4?
I want the best.
Thanks!
Old Mar 22, 2016 | 07:17 PM
Same stuff it's been for many years now - 75W140 full synthetic for the rear and 80W90 conventional for the front. 75W90 synthetic is okay for the front. If the rear is limited slip you need a bottle of Ford friction modifier, the e-locker doesn't need additive.
Old Mar 22, 2016 | 09:21 PM
la_leo's Avatar
I want the best.
Thanks!
What he said about full synthetic. I used valvoline with the correct amount of friction modifier. I bought the friction modifier of Amazon. Be warned it smells like *** so use gloves. I have an XLT without the E locker though. Just check your manual. It was a pain to do without a drain plug though, I used a suction gun to remove the old stuff. But if you have the money get yourself an aftermarket diff cover with heat fins and a drain plug.
Old Mar 22, 2016 | 10:19 PM
Any particular brand you guys recommend?
I'll check my vin, but I think I've got limited slip and an e locker.
Old Mar 22, 2016 | 10:44 PM
You have either a limited slip or an e-locker - not both. Limited slip needs modifier, e-locker does not. The VIN won't tell you, but what's the AXLE code on the door jamb sticker?
Any brand of fluid is fine, but you should use Motorcraft modifier if you have a limited slip. To do it right you need to remove the cover to drain the fluid, a suction gun won't get all the crap out of the bottom.
Old Mar 23, 2016 | 10:54 PM
Sorry for the late reply.
L6 is the axle code.
Old Mar 24, 2016 | 08:54 AM
tcp2's Avatar
L6 is a locker axle. you don't need friction modifier because it doesn't have slip clutches, but if the fluid you buy has it already in, it's not a problem. I would suggest ford's 75w140 gear oil or Redline's 75w140 fluid. Redline's has a higher amount of ester base in it which doesn't sheer in the same way as conventional fluids, even type III "synthetics", but Ford's fluid is good too. you will need to buy 3 quarts as it requires about 2.6 to fill. You will also need to clean the gasket material off the cover and axle and then re-seal with a gasket maker. I would suggest permatex gear oil gasket maker.
Old Mar 24, 2016 | 10:41 AM
Roadie's Avatar
Screw RTV. Use a gasket.
Old Mar 24, 2016 | 10:18 PM
la_leo's Avatar
You're right about using a suction gun not getting all the crud out. BUT I just did that for temporary purposes. I had my rear end rebuilt after the dealership screwed it up after incorrectly installing the flange that was causing a noise. Oh get this. The dealership used some sort of sealant on the rebuild. Don't know if they also used a gasket though.
Old Jun 25, 2024 | 12:59 PM
Chiingy thao's Avatar
how to make the gasket
I have a 2012 fx4 super crew 3.5 eco boost and autozone carries the 75-140 for cheaper but they say i need the friction modifiyer? Its confusing me cause i also have a L6 but they say i still need 4oz of it. Are they wrong or would it hurt to put it in there anyway?
Old Jun 25, 2024 | 01:50 PM
You do NOT want to use modifier with the e-locker. It won't hurt but it's totally not necessary. Just use straight 75w140 synthetic.
Old Jun 25, 2024 | 02:22 PM
Thanks man.
Old Jun 25, 2024 | 04:06 PM
Well apparently they sent me these instead. Will this still work? Or should I return
Old Jun 25, 2024 | 05:07 PM
Return the TransX.
