295/60/20 fit without leveling kit?
I have a 2012 FX4 5.0 luxury package. And I'm thinking of getting the Nitto Trail Grapplers 295/60/20. i'll be using my OEM 20 inch rims, but I also don't want to install a leveling kit. Will it fit without any rubbing? thanks in advance.
Great question. I was wondering the same thing earlier today. I was looking at Toyo A/T 2 though. It will be close. I'm running 285/55R20s now and tire to tire it says section width is wider on mine. But bit taller. Perhaps Bilstein 5100s on first climb up will work.
You should get at least a 2" level, and may need 1/4" wheel spacers so they dont touch the control arm. You at least need to with '04/'08 20x8.5 stock wheels.
Otherwise, the Toyo M/T is now available in 295/60-R20 and I think it is 33.80" tall.
According to Toyo's website... they are 34.2".
A/T 2s are 33.9 and overall width 11.9 which is interesting as my current 285/55R20 Toyo's overall width is 11.8 and I have room. I suspect these will not rub. Can't speak for M/T.
I've been waiting for Toyo or Nitto to add a 285/60R20. But perhaps if that doesn't happen a 295/60R20 will work.
My bud just put same toyo 275/65R20 on his stock no level 2011 and he as no rub or clearance issues. And that unit is 34.1 so height not an issue... But combo of 33.9 x 11.9 could be.
