Can it be done ?
Old Jul 16, 2013 | 05:15 PM
Threads have been merged. One thread per subject to reduce confusion.
Old Jul 16, 2013 | 09:35 PM
gDMJoe's Avatar
twctim ...
REMEMBER ... If you have 4x4 and you opt to change the RAR, you will need a corresponding gear change for the front.
BTW ... The OEM 3.73 electronic locking ear axle that you're referring to is a 4x4 option and isn't full-time selectable.
Old Jul 17, 2013 | 11:59 AM
mkosu04's Avatar
Originally Posted by dewalt17
Traction control cannot negate the fact that he has an open differential.
I know it doesn't change the open diff, but it will keep the right wheel from "just spinning" as he describes the problem.
Its hard to know what exactly he is asking since his writing skills are extremely poor. But it sounds to me like he is having trouble with one wheel spinning loose with no end to it.
Originally Posted by F 1Fiddy
All traction control does is shut the engine down when it senses slip. That doesn't have anything to do with whether you have two wheels pulling or one wheel pulling. It just means that the engine will shut down quicker because its a one wheel peel.
Actually, no it does much more than that. Traction control will apply the brakes independently at each wheel to counter loss of traction. Depending on the conditions it may also limit the engine power to help regain traction.
With the traction control on, it should be pretty much impossible to spin a wheel... as soon as it starts to break loose it will correct itself.
