Just purchased a 2011 FX4, have a few questions
Old Feb 6, 2013 | 10:05 PM
blownblu03's Avatar
Hey guys, I am in the process of buying a 2011 F150 Super crew FX4 with the 5.0 in it and I have a few questions:
1. How do I know if it has the max tow paxkage?
2. Do all FX4 trucks come equiped with the 3.73 rear with the E-locker?
What is the tow rating? It has the optional pin connectors but no brake controller.
3. The dealer told me the factory controller be installed if not built with it, is that true?
Attached is the link to the truck I am going to purchase. I live in NY and am traveling to get the truck. It is being purchased without seeing it in person and the dealer stated that if I get there and it is not what was explained the deal is off.
What should I be looking for when I get there?
http://franklinford.com/Vehicle_Deta...hicleID/367731
Old Feb 6, 2013 | 11:07 PM
Scarlet's Avatar
Cool
That truck does not have the max tow package. A dead give away is that the max tow package will have the large extendable mirrors. The max tow package WILL have the trailer brake controller, 7 pin receptacle (right next to the 4 pin), transmission cooler (pop the hood and the cooler sits in front of the a/c condenser to the upper right), upgraded radiater, extendable tow mirrors, 3.55 limited slip axle (3.73 is optional) although I'm not sure about the FX4, I have a Lariat. The dealer knows what it is. He's a ford dealer. Don't let him do a bait and switch. He wants to get you there and get your money. That's his job.
Old Feb 7, 2013 | 12:15 AM
BRUTE448's Avatar
if the deal goes thru keep posted on it as im looking at 2 11' FX4's right now but on the west coast they want upwards of $32K for them
Old Feb 7, 2013 | 01:21 AM
gDMJoe's Avatar
WELP! Here's the details as per the original ...
Window Sticker ««« -click-
Old Feb 7, 2013 | 08:43 AM
67Shelby's Avatar
Looks like everything mine has except the 20" wheels. I need to check my gear though. i may have went with 3.55. Noticed the larger fuel tank. 36 gallons. Man that will cost to fill up but you should be able to run a while on that. Good trucks though. Love mine. I think the towing capability without the max tow is 10,800 on the Ecoboost and the 5.0 is somewhere close in the same numbers. You should be able to install the factory controller without much issues. I think Ford has all the wiring ready, you just have to "plug-and-play". And on the max tow package, Scarlet was right. Dead give away on the mirrors. If they are the smaller ones, definetely not max tow. Big Super Duty mirrors on a smaller truck? Yes, max tow.
Old Feb 7, 2013 | 10:31 AM
blownblu03's Avatar
To tow my 03 cobra I assume I should be fine right? I take it to the track and some long distance shows from time to time and it is about 3hr ride.
The dealer is telling me that if not installed when truck is first built, you can not install the controller as an after thought. I call bs on that one.
I have a 2012 5.0 GT and I love it, I assume the 5.0 in these trucks are pretty close just less power.
Old Feb 7, 2013 | 10:33 AM
blownblu03's Avatar
I ended up getting the truck for $27,500 and a full tank if gas. Picking it up in about 2 weeks since it is a hike for me to go get it and I'm crazy busy. Can't wait to get it, first thing is a daystar leveling kit!
Old Feb 7, 2013 | 12:38 PM
Fireman Dave's Avatar
Thats a smoking deal on that truck, congrats! Also, the factory brake controller can be added if the vehicle has the towing package, (which yours does). I have a truck nearly identical to yours and it has the max tow package including the brake controller and it does not have the oversized mirrors.
Old Feb 7, 2013 | 12:50 PM
Scarlet's Avatar
Cool
Your tow rating, according to the brochure, with the 5.0, supercrew, short bed and 3.55's is 7,700lbs. If it were to have 3.73's it states 9,300lbs. You should be fine.
Old Feb 7, 2013 | 02:15 PM
Gerrard155's Avatar
Your truck has 3.73 gears. All FX4s from 2011-12 had 3.73 as the only axle ratio for the 5.0. You can have a TBC installed by the dealer. Guys have bought the part for about $100 online and installed it themselves easy. The tricky part is that the onboard computer has to be flashed to recognize the TBC. Some guys have gotten their dealer to do it for free(it takes a tech 5 min), some guys have had to pay an hour of labor-depends on the dealer. Also, if you are ever curious about what options a Ford vehicle has, just go to their website and view the window sticker for any car. Simply change the vin at the end of the web address and hit enter, and it will display the sticker for your vehicle instead. I have been able to do this on vehicles all the way back to 06, definitely nice tool to have when buying used. Congrats on the new truck!
Old Feb 7, 2013 | 03:50 PM
Hmmm....max tow pkg in the brochure says extendable mirror's and a heavier rear bumper plus trailer brake controller. Eco engine can tow up to 11,300lbs and the 6.2 11,200lbs. This pkg is plus what the standard tow pkg offer's.
Old Feb 8, 2013 | 03:44 PM
wanted33's Avatar
Man, what a deal you got on that truck. I paid more than that for a new 2011 4x2 XLT w/3.7L engine. Congrats.
Old Feb 9, 2013 | 08:46 AM
cdmm151's Avatar
Go here and put your VIN in right behind the equal sign and you will get your window sticker.
http://services.forddirect.fordvehic...icker.pdf?vin=
You can also get it from just click on the ford symbol.
http://researchmaniacs.com/VIN-Numbe...owSticker.html
Old Feb 9, 2013 | 12:04 PM
gDMJoe's Avatar
cdmm151 - Go here and put your VIN in right behind the equal sign and you will get your window sticker.
*.above ...
gDMJoe - WELP! Here's the details as per the original ...
Old Feb 9, 2013 | 08:57 PM
blownblu03's Avatar
Thanks guys, cant wait to pick it up. For some reason this dealer just wants noting to do with the brake controller so I am going to get it home then address it with my local dealer.
Does anyone have a article on how to instll the factory controller? I see that the FX4 has the E-locker, how do you guys like that? 9,300Lb is more then enough for me since the car, trailer, tools and people with a full tank of gas should be a toltal of around 6,600 to 7,000 at most.
Im shooting to get it this coming weekend, I am ordering the Daystar leveling kit for it right away and the brake controller
