Sponsored by: DashLynx
roush boost gauge vaccum help!!
Old 01-02-2013, 04:56 PM
mapes4's Avatar
Here is a picture of where I ran the vaccum line. When the truck is at idle it is showing around 15-20lbs of boost. Obviously this is incorrect....can someone tell me what I did wrong? Where does it need to be routed?
Old 01-03-2013, 03:02 PM
NASSTY's Avatar
That's where I have mine T'd into and mine works fine. Are you sure its not showing 15-20lbs of vacuum?
Old 01-03-2013, 03:49 PM
mapes4's Avatar
Yea, it is vacuum. Sorry for the typo. The needle is pointing down. I'm thinking that I may have just teed it in too close to the manifold. Do you think this would cause the problem?
Old 01-03-2013, 03:55 PM
Gipraw's Avatar
Does it move into boost when the engine is under load?
Do you have access to a scan gauge to see what the PID is showing for manifold pressure?
seeing vacuum in the 11-12 range wasn't uncommon for my SHO at idle
Old 01-03-2013, 04:44 PM
mapes4's Avatar
I do not have access to one of the scan gauges. It will show boost when under load...I have seen videos of other peoples' and they sit at 0 until giving it gas.
Old 01-03-2013, 05:28 PM
NASSTY's Avatar
That's normal. It should be around 15 @ idle.
Old 01-03-2013, 07:08 PM
mapes4's Avatar
Really?!? I never would have thought that! Thanks for the quick responses.
Old 01-04-2013, 09:42 AM
Gipraw's Avatar
probably just boost, instead of boost/vacuum
sounds like you are fine.
Old 01-04-2013, 10:53 AM
Shadow_Grey's Avatar
Do you have part numbers and pix of how you mounted the gauge on the inside? I am sure interested in doing this.
Old 01-04-2013, 11:34 AM
KRIEGHOFF's Avatar
Old 01-04-2013, 02:27 PM
IR0NS1N's Avatar
Mine shows 15-20 inches of vac at idle. All gas (Non diesel) motors make vacuum. Light throttle or cruise will show about 0-1psi.
Old 01-04-2013, 11:10 PM
Thanks for the link to the info. Just what I was looking for.
Old 01-05-2013, 02:55 AM
pfb2's Avatar
You are tee'd into the correct spot and your gauge is working properly...
Quick Reply: roush boost gauge vaccum help!!
