Gauge Cluster Swap
2010 cluster swap
not sure what you are changing here..are you putting the lariat cluster in what...(I don't know why lariat cluster is better looking than Xl or XLT)
I called my speedo shop on the 2010 XL & they said they could program the mileage also the anti-theft so I presume that could be done!! ( $100.00)
If as in previous years my 2007 XLT was plug & play but you would still have to reprogram the correct mileage...As I said I did a 2010 XL with an XLT but it wouldn't start re: anti-theft lite was on!! The real issue here would seem that if your truck's computer was not programmed & the truck was wired say for temp readout it will not work!! Maybe other stuff also!!
in previous years an FX4 would not swap into a XLT but a Lariat would & if I remember correctly the biggest issue was the climatrol & door ajar lite in the FX4 cluster !! Just my thoughts here???
just a further note my stealerships here in Ontario all said they could update the mileage..but they can't!!!!!!!
Hello i put a xf4 cluster into a 05 xlt today everything works except for the air conditioner engaging, i have read there is one wire i can move the pin placement to fix this without having the cluster married,4 250$ does any one know which wire color location an where to put it.i have seen it here before but i believe it was in 2009, thanks
Well, today, i just swapped out the gauge cluster from the stx standard cluster to the lcd display cluster and everything works, even without the arrows and ok buttons, the factory steering wheel buttons can move the cursor on the display. I paid 70 bucks for the cluster and couldnt be happier!!!
Is the screen just black
Info
