Spark plug replacement instructions 5.4L 2010
Old Oct 25, 2013 | 01:55 PM
What year and engine do you have?
Old Oct 25, 2013 | 10:17 PM
gDMJoe's Avatar
glc - What year and engine do you have?
Thread title/topic ... Spark plug replacement instructions 5.4L 2010
Old Oct 25, 2013 | 11:36 PM
I was not replying to the original poster, we need to make sure this new poster is in fact talking about the exact same year and engine. The way that people hijack old threads around here, you never know.
Old Oct 27, 2013 | 11:25 AM
canadianelbow's Avatar
GLC, perhaps you could answer the "why not antiseize the plugs" question. I'm a little curious too. It seems like a good idea on the surface......
Old Oct 27, 2013 | 04:03 PM
jntibs's Avatar
I'll try. As I understand it, anti seize will provide a false torque reading artificially low, therefore usually torqued too high when tensioned, therefore causing potential for broken plugs, or worse, a stripped out head.
Old Oct 27, 2013 | 04:31 PM
Not only that, if you use Motorcraft plugs, they are nickle coated and require no antisieze.
Sent from my iPhone using IB AutoGroup
Old Oct 28, 2013 | 11:43 AM
playingmechanic's Avatar
Sounds like a good reason for not putting the anti-seize on the threads.
I have a 2010 5.4L......anybody know what the torque values are for the spark plugs?
Also, do you recommend replacing the coil boot for each plug? I think they are $10 a piece, for $80 is it worth the value?
Old Oct 28, 2013 | 01:26 PM
Thank you for the clarification. Book torque value is 9 ft/lb, I think I'd get them tighter than that - probably at least 15 ft/lb. From what I've read, antiseize is not necessary but a VERY small amount wouldn't hurt and keep it away from the electrodes.
Boots are a lot cheaper than that online, but I don't think they are really necessary if replacing the plugs with the same OEM plugs. Clean them out and regrease them, try not to get any grease on the contact spring.
Old Jan 23, 2014 | 02:48 PM
yeltnarb's Avatar
How do you get to the last two plugs on the left bank without removing fuel rails? BTW, How DO you remove the left side fuel rails!! I'm "stop work" waiting on some answers. Thanks
