2009 keyless entry code!!
Old May 24, 2012 | 06:31 PM
z67's Avatar
z67
Sorry but I have searched the system and only find out about older year locations. All most were stating that the code was behind the drivers seat. Well I pulled all the info on removing the seat and there is nothing back there other than some old popcorn.
Were can I find the code on this 2009 supercab F150?
I looked for all logical locations but have not found it.
Any help would be appreciated.
Just purchased the truck two days ago so I am not familiar with the newer models.
Thanks for the help as always.
Old May 24, 2012 | 07:56 PM
GoingGoingGone's Avatar
I've heard various locations from under the dash by the radio to on the back wall of the cab under the carpet. Good luck...if you bought it from a dealer, couldn't they research it for you. You would think that a private party seller would have given it to you.
Old May 24, 2012 | 08:53 PM
blueovelboy's Avatar
is the card in the owners manual? mine has a credit card with it on there. and i believe its in the manual where it is ill go look in my trucks book!
Old May 24, 2012 | 09:19 PM
04 up Screws, on the BCM behind the back of the rear seat
Old Jun 2, 2012 | 12:43 PM
z67's Avatar
z67
Checked behind the rear seat,nothing. Checked the back of the fuse panel on the passenger side floor, nothing. There was a couple of stickers on the back of the panel but no codes. Bought it from a dealer but not ford. No card in the manual either. Just stopped by the dealer and they said they can get it but I will need to wait an hour because they have the computer on another car now. Not sure if they will charge me or not but I will find out.
Old Jun 2, 2012 | 01:37 PM
Chuck W.'s Avatar
Is the keypad a factory install or dealer installed? If dealer install you probably won't find one on the truck.
Old Jun 3, 2012 | 06:58 AM
efusilier's Avatar
Did you removed the trim after taking off the back of the rear seat? It should be behind the carpeted trim on the rear wall of cab.
Old Jun 11, 2012 | 04:45 PM
Ftruck09's Avatar
My truck does not even have the keypad yet it came with a code for one on an as described "credit card" in the owners booklet.
Old Sep 18, 2012 | 10:33 AM
Jeff Wassink's Avatar
Found my factory code on my 09 supercrew last night. Remove the cover/trim that covers the fuse box which is located on passenger side where a passenger's right foot would be. Reach towards the front of the truck and pull the cover towards you. (Owner's Manual gives instructions). Then you have to bend back the cover/trim that that was attached to. There is a black box mounted behind the fuse box which is the computer module . There is a sticker with a bar code and a large bold letter on it. There is about an inch of clearance between the sticker and the side wall of the truck, you will need a flashlight and good eyes. On that that sticker, on the upper corner closest to you is a 5 digit code which is the factory code, most of them start with a 1. (If the box was removed, it would be on the lower left corner, but the sticker is "vertical", which makes it the upper corner.) Then see your owners manual on how to customize the code if you want.
Old Sep 18, 2012 | 01:22 PM
maybe you can add it then?
Old Sep 18, 2012 | 09:24 PM
L8 APEX's Avatar
The dealer can pull it with the tech tool or it is on the back of the smart fuse panel in the passenger kick panel.
