2011 FX4 whining in 4 wheel Drive
I have 2500 miles on my new FX4 and engaged the four wheel drive for the first time last night, I was off road (in the yard) and noticed that something just didn't sound right. I took the truck to a dirt road this morning and have a whining sound with the 4x4 in high. The noise is more pronounced while accelerating. If anyone else has the same problem please post and let me know what you have found. I would like to be loaded when I hit the service department.
Thanks.
Thanks.
-John
-John
I've had this sound in my truck since new and it's still there after a 1.5 years. I posted about it here...
https://www.f150online.com/forums/20...elerating.html
Here's a video I did to demonstrate it. Don't worry, I don't normally drive on pavement in 4WD. I only did it this one time to make this video with minimum road noise. I kept in a straight line while 4x4 was engaged.
Seadragon,
If I didn't know better I would say that you made that video with my truck.
If you have this problem with a truck built 1.5 years ago there should be some type of solution from Ford by now. However, I would bet that when I walk into the service department with this issue they display the typical deer in the headlights look and say this is the first time they have seen this problem.
Same problem on F150 4x4 Whinning noise
Smokediver I have the same issue. Just purchased a new 2011 F150 Larait and engaged the 4 wheel drive and noticed right off I had a whinning/whistling noise only under acceleration when in 4 wheel drive. Took it to the dealer Tuesday and they found a cracked rear drive shaft and thought that was the problem. Got the truck back Wednesday and still has the same nosie. Headed back to the dealer next week. Truck has 1800 miles on it but has done this since the begining. Will let you know how things go. Don't hold out much hope after reading through these post.
