Hellwig Sway Bars, Got em?
Old Dec 8, 2011 | 11:56 PM
Bullet100t's Avatar
Has anyone installed Hellwig Sway Bars on there 2009 or newer F150?
I have a 2011 5.0L and am considering putting them on my New Super Cab.
I had a set on my 1998 F150 Lariat, and the truck handled like it was on Rails, it also had KYB Gas Adjust shocks. I loved the way that truck handled. I was hoping for some feedback on Hellwigs on a 2009 or newer F150. My new truck plows through corners, and a lot of Sway. Even with 1,400 miles on it.
MP Fort Worth, Texas
Old Dec 9, 2011 | 12:15 AM
Mike FX4's Avatar
I've been wondering the same thing.
This truck leans way too much around corners. I'm hoping to at least get a rear bar.
Old Dec 9, 2011 | 12:18 PM
gDMJoe's Avatar
Got 'em and have had them installed for a couple of months now. *2011 FX4 OFF ROAD, Super Cab, 5.0L
Comments:
  • installation ... STRONGLY RECOMMEND doing it on a lift. Yes, it's doable in the drive with floor jack and jack stands but expect MORE installation time. *Me ... Fortunate enough to have access to a lift.
  • fit and finish
  • improved handling
  • have noticed that at highway speeds you feel the bumps in the pavement more, however, to me it's a very minor issue.
BTW ... Part # 7705
Old Dec 9, 2011 | 08:27 PM
smunczen's Avatar
I installed one on my 11 fx4 last week. It's an easy install.
Old Dec 10, 2011 | 01:47 PM
projetmech's Avatar
i put a rear sway bar on my 05 f150 a few years ago. thinking about putting one on my 2011 that i now have. the 05 install was a breeze. did it on the ground in a half hour. cant see the 2011 being much different. made a big difference on the turns. it used to dive into the corners. after the sway bar it was if it were on rails.
Old Jan 1, 2012 | 12:38 AM
Bullet100t's Avatar
Anyone else put Hellwig sway bars on there 2009-2012 F150.
MP
Old Jan 1, 2012 | 10:55 AM
Scooter M'Gee's Avatar
I will be adding the rear bar to my XL standard cab long bed. I have heard almost all positive feedback on the bar. The only negative feedback was it stiffens the rear suspension up a bit and is slightly less compliant over bumps.
Old Jan 1, 2012 | 11:09 AM
L8 APEX's Avatar
I have one. Just watch the over steer in evasive maneuvers. Stock the truck under steers heavily. With the bar on I have pitched the rear out swerving to avoid deer and debris in the road. That is all I have noticed.
Old Jan 1, 2012 | 08:03 PM
Rotorguy's Avatar
I too have the Hellwig rear anti-sway bar installed on my 2010 2wd Screw. Install was easy and I did it without a lift. Took me about 1.5 hrs to install, but I spent some time lining it up with a level and tape measure....I know, a little ****
Been on the truck about 6 months and there is a definite improvement in rear stability around corners. It still handles like a truck, but more stable and controlled. The bar is adjustable and I am set on the middle hole and will leave it there for now. I have not encountered any oversteer on my F150 since the bar was installed.....now my Mustang, well that's a different story.
Best price I could find online was from Amazon, so they got my business. I would definitely recommend this mod!
Old Jan 2, 2012 | 12:22 PM
speedfreak's Avatar
Just installed these (frt & rear) on my lowered '11 Lariat Limited. It's only been two days but the difference is huge and immediate. Highly recommend this mod.
Old Jan 3, 2012 | 11:42 PM
Bullet100t's Avatar
Rear Bar
Does the truck have a Rear on it from the Factory, my 98 did not have a rear bar.
Mark
Old Jan 4, 2012 | 12:14 AM
Mike FX4's Avatar
My 2010 has no rear bar.
Old Jan 4, 2012 | 08:59 PM
Rotorguy's Avatar
Mark
No factory rear bar. I added the Hellwig rear and kept the factory front bar.
Old Jan 4, 2012 | 09:00 PM
smunczen's Avatar
No factory rear sway bar for the F-150.
Old Feb 20, 2012 | 12:38 AM
Bullet100t's Avatar
Anyone else have Hellwig Sway bars on a 09 or newer F150?
Mark
Fort Worth, Texas
