3rd brake light ebay
Old Nov 30, 2011 | 09:21 PM
Formula jg's Avatar
Anyone install this:
http://cgi.ebay.com/ws/eBayISAPI.dll...302#vi-content
If so, how was the fit and light brightness at night?
Old Nov 30, 2011 | 10:56 PM
gDMJoe's Avatar
Formula jg - Anyone install this:
Have had it installed for 3months now. Comments:
  • despite what the ad indicates, it DOES NOT "Install...using existing factory plug". *It needs to be spliced into the bulb socket wires -or- (as I did) fabricate a connector that plugs into the bulb sockets.
  • fit is
  • brigtness (day|night) is *CAVEAT: Since I have a hard tonneau cover I only wired-up the stop-light.
FYI ... The manufacturer is PILOT and the part # is TB-205S.
Old Dec 1, 2011 | 08:19 AM
Formula jg's Avatar
So did you add a connector to the ends of the 3 wires so it plugs into the factory connector that holds the oem blub?
If not, please discribe in a little more detail what you did there.
Old Dec 1, 2011 | 10:41 AM
Formula jg's Avatar
...Forgettaboutit...
This seller wants $49.99US to ship 1 of these lights to Canada via USPS.
Is this guy greedy or am I not in touch with reality....
Old Dec 1, 2011 | 12:45 PM
gDMJoe's Avatar
Formula jg - So did you add a connector to the ends of the 3 wires so it plugs into the factory connector that holds the oem blub?
Yes. Except that since I didn't intend to use the cargo light(s), it only involved 2 wires ( red and black ) and 1 connector.
  • bought a light socket pigtail that matched the existing.
  • converted it to a male ...
    • 2 sections of 14guage copper wire stuck into the connections in the socket.
    • then filled the socket cavity with silicone adhesive (NOT sealant).
    • after setting-up, trimmed the 14guage copper wire prongs to the appropriate length.
  • attached the red / black wires to the male socket (twist, solder, shrink-wrap).
The new, male socket now plugs into the bulb socket and the two are held together via a lengthwise zip-tie.
NOTE: I'm **** about cutting / splicing into OEM wiring and trust me ... THERE IS NO READY-MADE MALE COUNTERPART TO THE BULB SOCKET (other than a bulb). YA! I LOOKED!!!!!
To use the cargo light(s), you'd need another socket pigtail and make a male socket with 1 14guage copper wire pin. The lead for that pin would be attached to the white wire and the male socket would plug-into either of the cargo light sockets as white <> white. *Ground is shared with the stop light and their hot is shared between the 2.
Old Dec 1, 2011 | 01:04 PM
gDMJoe's Avatar
Formula jg - ...Forgettaboutit...
As you probably already know ... Some will not ship at all to CA.
FYI ... That's the best price that I've seen and MUCH less than I paid in Aug'2011 from another eBay seller.
If you're up-to a leap-of-faith let me know ....
  • provide me funds.
  • will purchase item.
  • you provide funds to cover shipping co$t.
  • will ship the item.
But 1st to determine the UPS shipping co$t ... NEED YOUR CITY -AND- POSTAL CODE, eh?
Old Jan 3, 2012 | 01:28 PM
Formula jg's Avatar
gDMJoe,
Is your offer still good?
Old Jan 3, 2012 | 01:49 PM
gDMJoe's Avatar
Formula jg - gDMJoe, Is your offer still good?
Yes sir. But as noted .....
Send info' in a PM.
Old Jan 3, 2012 | 04:49 PM
Formula jg's Avatar
You have a PM.
