Sponsored by: DashLynx
Leveling Kits for 2011 F150 FX4
Old 07-02-2011, 09:34 AM
NASSTY's Avatar
Originally Posted by jgardn1
@NASSTY
Truck looks very good. Just curious if this setup and tires made fuel economy drop much? Thanks
According to the Lie-ometer I lost about 1.2 mpgs in town .I haven't done any extended highway trips so I'm not sure about highway mpgs. Either way it's worth it for the look. It still gets more mpgs than my 06 5.4 3v did so I can live with the slight loss.
Old 07-02-2011, 03:11 PM
russ10screw's Avatar
Originally Posted by 06yz250f
you will want to stick close to the specs he posted. you can fit up to a 35" tire on stock wheels. if you get a tire with much more backspacing you will start running into rubbing issues.
offset and backspacing are directly related to each other, google offset to backspacing chart and something should pop up to tell you backspacing to offset and visa versa.
Thanks. Yeah I understand offset and backspacing. I was more asking how much additional space he had before rubbing would start occurring. In other words, if he went to a 9" wheel with the same specs, would that 1/2" be a deal breaker and start creating problems. Or if you went to a 9" would you have to adjust the offset or backspacing value to make it fit. I've heard of most people either going 33's or 35's. The 34 is somewhat intriguing.
Originally Posted by philly164
I am using 1/4" spacers in the front just to get away from my UCA a little more,,love the autospring,,truck rides great!!! thank you!!!!
Awesome. Were you having any rubbing issues prior to the spacers or did you just do it for precautionary measures?
Old 07-02-2011, 05:39 PM
Originally Posted by Seelb0
I finally decided to buy a Ford and I love it. Plan on putting a leveling kit on it and 35" tires. Any suggestions and what brand & size leveling kit to get? Thanks for any feedback.
How about some more specs on your truck? A 2" kit will probably clear a 35 OK but 33's or 34's may be more practical. If your planning to use the stock wheels I would limit tire width to 12 inches because a 12.5 tire is close on the inside when turning. I just had my leveling kit installed this morning just across da bayou from you! I'm over in Lockport
Old 07-05-2011, 10:29 PM
dave m's Avatar
here's my 2010 with a 2 1/2" leveling kit and 325/60/20 on the stock rims. 1/4" spacers all around, with very, very minor rubbing at full lock.
Old 07-11-2011, 11:35 PM
Seelb0's Avatar
Uploaded the before and after pictures on my profile. Really like the look after the leveling kit was installed. Hate to say it but I need some pointers on how to upload pictures on the forum topics. Thanks
Old 12-22-2011, 07:23 PM
jkringstaff09's Avatar
Those tires and leveling kit fit perfectly with your truck, NICE. What kind of leveling kit did you use and what brand are your tires??
Old 12-23-2011, 12:41 AM
NastyFX4's Avatar
Do you guys think 33s will fit with a 1-1/2" leveling kit on OEM wheels?
Old 12-23-2011, 01:10 AM
Is that only a 2 1/2" level up front? No additions to the rear? What brand?
Is this going on your truck? If not, still a 4x4? You could definitely fit 33's with a 1 1/2" level.
Old 12-23-2011, 01:41 AM
hrdude's Avatar
Yes, 33's will even fit without a leveling kit on 4x4 models. However, they will look a bit better with some level.
Old 12-23-2011, 02:08 AM
NastyFX4's Avatar
Yes, it's a FX4. I'd like to fit 35s but I know I'll probably need more of a lift. I don't want to lift the rear and my truck doesn't seem that unlevel.
Old 12-23-2011, 09:23 AM
What about a 34 inch tire, they ought to fit with a 1 1/2 or 2 inch level easily depending on the width of the tire.
Old 01-15-2012, 10:41 PM
CodemanKTM's Avatar
Originally Posted by NASSTY
That's what I got. 2" Autospring with 295/60/20 (34")Trail Grapplers.No trimming necessary with 34's, you may need to trim a little for 35's.
What does that bring the height of your truck to. I want to do the same thing but want to make sure I can still fit in the garage door.
Old 01-16-2012, 03:49 AM
NASSTY's Avatar
I'm not sure of the height but it fits in a garage with 7' doors.
Old 01-16-2012, 11:39 AM
CodemanKTM's Avatar
thanks NASSTY!
Old 01-19-2012, 08:40 PM
repieces's Avatar
For those that are running spacers, what brand do you have? My front tires are barely rubbing the upper control arms and I need to kick the tires out 1/4" or so.
Quick Reply: Leveling Kits for 2011 F150 FX4
