Fumoto Valve F107N?
Old Apr 9, 2011 | 12:46 AM
gasbrnr's Avatar
Fumoto Valve F107N?
Anyone know if this valve fits the Ecoboost? I was told it's the right one, but want to make sure. They make an extension if the drain plug threads are recessed in the oil pan. I looked under an EB at the dealer but with the skid plates I couldn't see the drain plug.
Old Apr 9, 2011 | 07:19 PM
boomer08's Avatar
Yes I ordered theat exact one and had the dealership do the first change and put it on for me.
Old Apr 9, 2011 | 11:09 PM
gasbrnr's Avatar
Cool thanks Boomer08, I'll order one up!!!!
Old Apr 10, 2011 | 05:08 PM
TX Chris's Avatar
I assume the nipple is for hose attachment to drain into the pan via hose instead of simply letting gravity take over and splash where it may?
My EB is on order and I haven't seen under one yet, so I don't know if the drain is on the bottom or side of the pan. If on the bottom, will this valve become an instant target for road debris?
Old Apr 10, 2011 | 05:38 PM
gasbrnr's Avatar
I have had the Fumoto with nipple on all 5 of my last trucks and never had an issue. I did own 4X4's but even with 4X2's I think you'll be fine. They don't hang dowm much at all and the nipple is cool, attach the hose turn the lever and come back in 5 minutes your done. No splash not even a drop of oil on your hands! I put the hose directly into the oil recovery tank through the small hole. So you don't need a drain pan.
Old Apr 10, 2011 | 10:22 PM
jmmec's Avatar
And will the same valve (F107N) work on the 2011 5.0?
Old Apr 11, 2011 | 12:30 AM
gasbrnr's Avatar
JMMEC yes same valve!!
Old Dec 22, 2012 | 05:32 AM
NastyFX4's Avatar
It clears everything on the 5.0? Isn't there something right by the oil pan on the 5.0L. Brain fart...
Old Dec 23, 2012 | 01:36 AM
NastyFX4's Avatar
Bump!
Old Dec 28, 2012 | 03:18 AM
NastyFX4's Avatar
Anyone?
Old Dec 28, 2012 | 05:42 AM
svt2205's Avatar
Should be just fine.
Old Dec 28, 2012 | 09:48 PM
NastyFX4's Avatar
Has anyone used the F107S?
