2010 F150 Stall
2010 F150 Stall
I bought my truck back in April 2010 and love every moment of it; XLT, 4.6 liter, 3 valve, 6 speed transmission, 5 1/2 bed size, XLT Chrome Package, Power Package, and Tow Package. I even added a BakFlip F1 and modded the reflector on each side mirror and turn them into an actual working turn signal.
Here is my situation, my engine stalled back in June, August, October, and now December 2010. It always occur unexpectedly when I am making a turn; voila, the engine just dies, absolutely NO power, no steering, and the brake pedal is hard to depress (stopping is impossible if you do not have the strength). I absolutely DO NOT allow my wife to use the new truck whatsoever for her safety and for the safety of my children. Anyhow, I have always followed three simple procedure to get out of my situation/predicament; (1) put the drive selector back into 'PARK' position, (2) put the key back into OFF position, (3) make sure all accessories are off, and then (4) turn the truck back ON. This procedure has never failed me BUT this is getting very dangerous and to add SALT into the injury, the people around me would say, "Wow, that is a brand new truck made by FORD and it stalls for no reason. Hmm, no wonder I don't buy American trucks!" Argh! my first American truck not at it's best; believe me, I am very proud of the truck but just not the quality. The SADDEST part about this is that I called the local Ford dealer, Cerritos Ford here in California, and I finally had the car inspected during my oil change but to my surprised they stated that there was (1) no problem with the truck and (2) there is no RECALL for this particular model (all is well, normal and healthy). I even mentioned to them to check the OBD computer ... and that too was hopeless since the dealer checked it out and to my surprise there is also NOTHING to note; everything in the system is fine. Well, after the first two stall, I would automatically run the sync 'Vehicle Report' hoping to capture anything and that too is hopeless. Needless to say, I have had two more incidents after the oil change and the dealer has the same answer.
So here I am very FRUSTRATED since the truck is not living to what it is suppose to be, Ford Tough! There is no toughness in my situation; only my frustration is getting tough. I have filed a complaint to NHTSA hoping that FORD would look into this. FYI: there are several complaints filed already related to engine stall (2010 model).
Question: has anyone experience this situation? If so, did the dealer look into this for you? What was the out come? Please let me know because I am ready to file a 'Lemon Law' very soon (three strikes, this truck is out).
My GF had a car that did that .She suspected the computer. The third time it happened she called Detroit and told them to replace computer .They did and there was no more problem !!
In any case you have a truck that has a dangerous condition. Don't drive it ! DEMAND action -replace parts - new vehicle etc.
2010 F-150 engines stalls
Good day everyone,
I bought my 2010 F-150 (brand new) 2 months ago and I am having the same issue. The engines stalls unexpectedly while driving or while being on Park gear.
I have not reported this issue to the dealership yet, but will this week.
Has anyone experienced the same issue and by any chance gotten it fixed by Ford ?
I also have a 2010 4.6l 3v with the 6spd, and mine at 2,500 miles stalled while starting to leave a stop, hit the gas all the sudden no power.. looked down and it wasnt running when 30 seconds before that it was when i stopped.. I'm not even going to bring it up to the dealer because they wouldnt be able to "recreate" the problem and just waste alot of my time. If it happens again then ill get into it with ford.
im kinda getting sick of this with fords. My boss had an 06 f-150 that stalled at odd times, my work truck is an 06 f350 v10 and that stalls at odd times repeadily, my 05 fx4 with the 5.4l did it a few times in the three years i owned that too. My bosses chevy 1500 never does this, nor does my chevy ck2500 work box truck with the 6.0l, cant see why ford cant make a vehicle that doesnt stall.
I've dealt with dealers before unless i bring it in stalling to them they wont do anything, so im not wasting my time with it.
Read this can be a few different things:
1) Loose connection in air intake (don't think this is your issue as I would think you would be stalling more often).
2) Transmission issue, bad valve body causing the transmission to lock during idle.
3) Software issue, reflash with newer version or replace PCM.
Thank you all for your comments.
I know since the first time it hapenned that I will have a hard time to get Ford to fix thhat problem....they first need to recreate it then good luck to figure out whats causing that....
Its like back pain....can't prove it to the doctor...but its there hurting you 24/7.
I will let ou guys know the verdict as soon as Im back from the dealership.
But I am quite convinced...somebody, somewhere in north america has had the same problem....fixed ! Where is that person that I need to talk to !!!!?
i have seen this on a few of the older F150s 04-08 before they did the 3 valve 4.6 in the F150s and on mine too (07 2 valve 4.6) where it was the throttle body killing the truck or causing rough idle even with no codes i worked on one the other day where the customer came in and requested replacing the spark plugs well did them and while test driving it drove fine but came to a stop and the rough idle started and went to take off and it died started up fine tho and drove back to the shop just fine checked for codes and it had nothing come to find out the customer was wanting to do spark plugs to fix his dying issue
Found this thread on another forum. http://www.fordf150.net/forums/viewt...p?f=69&t=90646
Were where the trucks built that stalled? Whats the build date?
