Raptor SCREW boards on FX4 SCREW?
Old Dec 7, 2010 | 08:08 AM
Landlocked's Avatar
I tried a search but can anyone tell me if the Raptor boards fit the FX4 and any opinions on how it would look? (trying to avoid the painted stock bars and no chrome)
Old Dec 7, 2010 | 09:33 AM
FX4life's Avatar
I don't see why they would not fit.. cabs on both models appear to be the same. I'm sure you'll pay through the nose for those step boards though!
Old Dec 7, 2010 | 01:50 PM
RickyBobby's Avatar
They should fit. The supercab boards are $412.50 each side, I would guess the supercrew ones will be slightly more.
Old Dec 7, 2010 | 01:59 PM
FX4life's Avatar
412.50 per side I hope the OP really wants these damn things!
Old Dec 7, 2010 | 02:53 PM
Landlocked's Avatar
YOWSA!! I just saw them on our Canadian site listed as an option for $700
per side!! I guess that makes the decision easier
Old Dec 7, 2010 | 03:33 PM
F150Aggie's Avatar
Here's what I did if you want the running board look instead of the bars. Used boards off of a King Ranch coated in Line-X
F150Aggie's Avatar
double post
Old Dec 7, 2010 | 04:47 PM
Wes28376's Avatar
Those are nice boards, but not $800 nice.
Old Dec 7, 2010 | 06:41 PM
FX4life's Avatar
I'm a fan of no running boards, nerf bars, or any visible step it's a much cleaner look without them. Just get yourself some electric steps from amp research, I have them and love them to death.. Then again if you divide the price by 2 they cost about as much as the raptor boards
Old Dec 7, 2010 | 08:17 PM
torque_monster's Avatar
I wonder who makes the boards for Ford, it'd be nice if we could get them straight from the supplier!!
Old Dec 11, 2010 | 03:40 PM
JKOL's Avatar
I have an FX4 also and have been wanting to see how these look. I am avoiding chrome like the plague. Not to mention, the Raptor boards are very low profile, as opposed to some other options that seem to hang halfway to the ground.
My only concern is how far they stick out. It looks good on the Raptor given the 3.5" flared fenders, but not sure how it will look on the less aggressive FX4. It might just be my imagination, they may not stick out any further than standard steps.
Old Dec 18, 2010 | 02:11 PM
butopia's Avatar
Talking how to install king ranch running boards on screw
[QUOTE=F150Aggie;4419266]Here's what I did if you want the running board look instead of the bars. Used boards off of a King Ranch coated in Line-X
QUOTE]
Aggie dude. You got any advice on installing the KR running boards? I bought a pair from someone and putting them on 2010 XL screw.
Weird thing is I have 11 bolts and then 11 bolts with a clip. Can't figure out which bolts go where and if I have enough.
Do you find the bedliner spray really a good idea (peel off in the future?).
Thx in advance for your wisdom and advice.
Old Dec 18, 2010 | 07:21 PM
F150Aggie's Avatar
Yea they were pretty annoying to figure out how to install them. But once I figure it out the rest went on like butter. I assume you mean 11 per side and 22 total? That's what I had. Basically if you hold up the board to the underside of the truck you can see where they attach. I didn't see the holes at first because there was tape covering them. You clip the speed nuts into the holes, then hold the brackets up to the holes, and thread the bolt into the speed nut and tighten. I'll try to take pics but I can't until Monday.
And I went with Line-X and it is perfect. Find yourself a good shop to spray it. It looks great with no peel and has good grip so you don't slip.
Old Dec 20, 2010 | 09:47 AM
butopia's Avatar
>>>>I assume you mean 11 per side and 22 total? That's what I had. .....You clip the speed nuts into the holes, then hold the brackets up to the holes, and thread the bolt into the speed nut and tighten. <<<<<<
Ahhhh should there be 22 of everything? I have 22 nuts but only 11 of the little angle bracket things. Ford parts house says they only come with the entire running board package. I'm thinking that I may just need to find stainless or galvanized bolts the right size and then make do. Found all the holes, now just gotta figure out a way to securly attach. Thx for your help in figuring out the puzzle.
Old Dec 20, 2010 | 10:34 AM
F150Aggie's Avatar
you can use the speed clips for the upper holes, and just use a set of nuts and bolts for the bottom ones. That's what I had to do when I was missing one of the clips.
