Airlift on My Platinum
Old Nov 18, 2010 | 09:10 PM
dubsesd's Avatar
installed the airlift kit on my truck. rides better than before with less "bounce" to the bed. lifts the rear end about 3/4" at just 17 psi when the truck is unloaded. and even at 20psi it still rides awesome. better pics with different heights and loaded with weight comparisons to come.
Old Nov 18, 2010 | 10:08 PM
savage02's Avatar
WOAH PRETTY COOL! What brand and size tires you runnin?
Old Nov 18, 2010 | 10:30 PM
dubsesd's Avatar
305/55/20 hankook dynapro ATM
Old Nov 18, 2010 | 11:19 PM
rcherry11's Avatar
Subscribing
Old Nov 19, 2010 | 03:06 AM
johnjohnson78's Avatar
Looks sweet! I'd love to smooth out some of the rear bounce in the back in my FX4.
This is a noob question, but does the airlift kit replace the rear blocks? If not, did you keep your 3 inch blocks?
I was also curious if your bilstiens helped smooth out the ride much compared to the factory shocks?
I'd have to imagine the truck is feeling great with 5100's and now the airlift rears
Old Nov 19, 2010 | 06:09 AM
dubsesd's Avatar
I didn't replace the blocks. Everything is the same as before. If I add 5-10 psi it doesn't affect the height but does smooth out the ride. Installing bilsteins today since they were on backorder, but I can only imaging the ride with improve even more
Old Nov 19, 2010 | 06:44 AM
Haulin' Dogg's Avatar
Good looking truck! What's your air source, and where did you install compressor or fill valve(s)?
Old Nov 19, 2010 | 07:28 AM
dubsesd's Avatar
Fill valve is out the back near the hitch . More pics tonight.
Old Nov 19, 2010 | 09:59 AM
D'REDRUM FX4's Avatar
Is this for the most part a straight forward install? Nice looking truck too
Old Nov 19, 2010 | 10:16 AM
dubsesd's Avatar
Yes. No drilling or custom fabrication. 1 hour install with access to a hoist
Old Nov 19, 2010 | 10:21 AM
Tedsiky's Avatar
Which Air Lift kit did you purchase? I want to make sure I buy the correct one.
Old Nov 19, 2010 | 10:47 AM
dubsesd's Avatar
There is only one for our trucks. 2000lb kit for 2008-2010 f150
Old Nov 19, 2010 | 12:07 PM
deleted
Old Nov 19, 2010 | 03:12 PM
Here's pic's of my Firestone bags and dual valves. Agree with Dubsesd, a little psi in the bags (7 to 10 psi) has improved on an already good ride. Firestone is also a no drill install, took about an hour per side using standard wrenches & sockets.
Old Nov 19, 2010 | 04:13 PM
wandell's Avatar
Sweet Screw!!
