Largest tires without a lift????
Old Nov 17, 2010 | 09:17 PM
texas_superman's Avatar
im curious if anyone knows the largest tire size that will fit without a lift on a 2wd. Id consider a AS level up front if needed? Im looking at 33" IS THAT POSSIBLE?
Old Nov 17, 2010 | 10:29 PM
wandell's Avatar
You can fit a narrow 33 inch tire (33x11.50) like a 285/70-17, 285/65-18 or 285/55-20 without a lift by using the OEM wheels. They will look much better with a leveling kit however.
Old Nov 17, 2010 | 10:38 PM
brazzeal15's Avatar
Ive seen a guy CRAM 35x12.5x20 toyo m/t under his 2wd KR with the 20" stockers. It was insane to see. And looked surprisingly good. But he had quite a bit of trimming on the back of the fenders up front. Overall, well worth it. But i would recommend wandell's suggestion.
Old Nov 17, 2010 | 10:39 PM
im looking at some 305/55/20 and probably a 2" AS level... what do you think? Mounted on 20" '09 FX4/Lariat wheels
Old Nov 17, 2010 | 10:41 PM
damn 35"s on a stocker, that is crazy... id think he would rub and bump with every little bump in the road...
Old Nov 17, 2010 | 10:45 PM
brazzeal15's Avatar
He said that he had no problem. This was a few years back. I wish I would have poked around underneath it a little. It was insane. Like an inch of clearance up front. It looked pretty sweet. But again.. I would not recommend. Ha. 33" is perfect.
Old Nov 17, 2010 | 10:53 PM
haha yeah, 33" def sounds better.
Old Jan 4, 2011 | 04:58 PM
subrubicon16's Avatar
im looking for the same setup, i have a 2wd fareside.
if i put a 2in leveling kit on it, can i cear 35" open country mt's with no problem?
help please, because im really hating the rim and tire setup i have on it now, i bought it like this used.
