No more tail gate pole! + Line-X
Old Jul 21, 2010 | 09:06 AM
ChrisT's Avatar
^ Is there a weight limit warning with that step? Just curious. I would hope they would have it set to around 300 lbs or so, for the exact reason you mention - weight of person and any cargo they may be loading up.
Old Jul 21, 2010 | 01:22 PM
Pappy1's Avatar
Looks great......I use to Own a Line-X shop.....sure is some great Stuff.....
Old Jul 21, 2010 | 02:24 PM
Bomeyer15's Avatar
I just had mine Line-Xed but I kept the pole and cover stock. He Line-Xed the tailgate up to the edge of the tailgate cover. I like having the pole since my balance is not as good as it used to be and I fall over from time to time (especially after the 3rd beer)
I do like what you did and I think it turned out very nice!
Old Jul 21, 2010 | 05:05 PM
2manytoyz1's Avatar
The Ford website says 350 lb rating.
http://www.fordvehicles.com/trucks/f...#page=Feature6
Old Jul 21, 2010 | 09:45 PM
juneau76's Avatar
I'm short and the step is handy for that, but I'm impatient and don't take the time to use it. I dig the thought of getting the metal panel and losing the stripper pole. Does it come primed/painted? Just curious. Great idea, thanks!
Old Jul 21, 2010 | 10:54 PM
Sonoma Super Crew's Avatar
It comes black. Would need to be either painted or Line-Xed.
Old Jul 22, 2010 | 05:15 PM
ommegang's Avatar
If I want to keep the pole, I don't use it but, I see no need to discard it, can I simply remove the plastic and just have it sprayed w/o ordering the metal part affore mentioed?
Old Jul 22, 2010 | 06:09 PM
You can just take the black plastic tail gate cover piece off and keep the pole but that area the panel normally covers would be left wide open. Not really an option.
Old Jul 27, 2010 | 10:37 AM
kapekawd's Avatar
Just ordered the parts from TascaParts.com (had to call, something wrong with credit card processing). Panel $46.12, bolts $1.08 (x8). I called my local dealer for a price quote and they quoted $88 for the panel!!
Old Jul 27, 2010 | 05:32 PM
4x4wolf's Avatar
Bed looks very well done
Old Jul 27, 2010 | 07:40 PM
2010 Blue SCrew's Avatar
Looks good! I'm getting ready to have my bed Line-X'd, too. How much did that run you, and which shop did it?
Old Jul 27, 2010 | 08:08 PM
looks great, good job!
Old Aug 29, 2010 | 09:54 PM
kapekawd's Avatar
I finally got the part (undamaged after first one received had bent corners everywhere). After removing tons of screws, lifting the plastic cover off, then removing the actual handle assembly (6 screws), I tried putting the new panel on and found it didn't fit. I had to cut off 2 plastic tabs that were preventing the new panel from sitting flat on the metal the way it was supposed to. Quickly cut those tabs off, put the panel in and screwed it down. I'll be making my LineX appointment very soon.
Old Sep 24, 2010 | 10:35 PM
rus's Avatar
rus
You haven't lived life until you've done 110mph in a Yugo
I have been there and done that in my old 1990 Yugo convertible .
Love the Line-x cover for the gate. Will check to see if will work on the 08 Superduty gate I have.
Old Sep 25, 2010 | 11:05 AM
Chris J.'s Avatar
Looks great!! I just purchased a 2009 fx4, and was thinking about getting a line x. Is that the line x xtra??
