new here
i take back what i said, there is a wheel that i like and want - i just cant afford it at $200 a wheel
method:
oh! forgot to mention - thanks to the lovely federal government i was able to order my magnaflow exhaust today (#17107) through my buddy for the low low price of 60% off
method:
Damn, that jeep thread is crazy! In just spent an hour looking thru it and didn't even make a dent... Crazy! Your got more dedication than me... Every time i do something to mine i mean to take pictures to do a sort or build thread, but always get too excited and forget ton take picture.... Keep up the great work!
catback, the full exhaust redo with long tubes is down the road.
its the magnaflow offroad pro-series. it dumps just before the rear axle
Since nobody has asked yet, how do you like te tires? How are they wearing? How do they ride? Your truck looks amazing man. Im definitely going to be using yours as inspiration while modding mine.
They ride great. I honestly can't tell a difference in ride except better performance in the corners and over high speed bumps and potholes. The sidewalls don't flex nearly as much
unfortunately i was not able to snag any pictures tonight - id prefer to wait for night shots as im a sucker for long exposures - so tomorrow will have to do i suppose! really all my DIY's are about 20 minutes of disassembly, set up my painting or whatnot area and do it really quick and then come back to it
right now is a break for a while. im trying to figure out if there is anyway of disabling the TPMS (E ply tires dont like 35PSI) or recalibrating them for a lower pressure. so far there is nothing available that i can find which is incredibly frustrating.
im waiting to figure out what my taxes are for last year and if things end up being positive for me id like to get my hands on a SCT X3 Excalibrator from VMP, and im looking at modifying the factory intake tube into high flow CAI which i hope will have my name stuck to it in the mod books
Where did you get 47lbs? My ideal pressure for these tires would be around 28lbs
The TPMS sensors themselves are calibrated to 33lbs to go off, you can't change what pressure try do that at as it's not in the computer. The recalibration is for location base only. Say you have a super duty and you're running 80lbs in the front and 55lbs in the rear. When you do a rotation itd be off
Right now I'm just running 35lbs so I don't have to screw with it, because there is no way to turn the TPMS system off
The 47 was a number I pulled out of my ****......
Had to use something, and it seemed like a great non round number. I'm assuming you know more than me about tires, but 28 sounds incredibly low for a set of 35x12.5's From the threads I've been reading, I thought if you increased tire size and got into a LT, you needed higher pressures, and I swear I've read that most guys are running above 40, and alot over 45 with 35's? My memory ain't great, and I'm too lazy to dig.
28 you say? wow! sounds more like an off road rock climbing pressure than a street pressure. But, what do I know?
Had to use something, and it seemed like a great non round number. I'm assuming you know more than me about tires, but 28 sounds incredibly low for a set of 35x12.5's From the threads I've been reading, I thought if you increased tire size and got into a LT, you needed higher pressures, and I swear I've read that most guys are running above 40, and alot over 45 with 35's? My memory ain't great, and I'm too lazy to dig. 28 you say? wow! sounds more like an off road rock climbing pressure than a street pressure. But, what do I know?
on my jeep i was running Goodyear MT/R Kevlars in 37x12.50x17 and they were a D-ply. my jeep weighed in at 4900lbs curb and i ran 22lbs of pressure in my tires to keep them flat on the road. when we were offroad we regularly ran 10PSI with non-beadlock rims for traction. when i upgraded to my Walker Evan's Beadlocks i regularly was hanging around 2-3PSI. note how the front driver tire is around 17" wide
this photo was of me running 5PSI in Lower Rock Garden at Black Mountain
and if anything, LT signififies hard rubber content:
Originally Posted by tirerack.com
LT = If a tire ends with "LT," it signifies the tire is either an earlier "Numeric", "Wide Base" or "Flotation" Light Truck size designed to be used on vehicles that are capable of carrying heavy cargo and towing trailers (Numeric sizes), use 16.5-inch diameter rims (Wide Base sizes) or are wider, oversized tires designed to help the vehicle drive on top of loose dirt or sandy surfaces (Flotation sizes). This includes light, medium and heavy-duty (typically 1/2-, 3/4 and 1-ton load capacity) pickup trucks and sport utility vehicles. Tires branded with the "LT" at the end of their size designation are also the "little brothers" of 18-wheel tractor-trailer tires and are designed to provide substantial reserve capacity to accept the additional stresses of carrying heavy cargo.
so marshal how do you like your ready lift blocks? i like how durable they look but is there really a need for intergrated bump stop? your truck is coming together awesome... wishing i started my own mod thread
i like the blocks. theyre sturdy. there isnt a need for the integrated bump stop unless you're running larger than stock tires. obviously as the diameter of the tire increases the need to stop the axle from moving up at a certain point does too.
thanks for the complement. and its never too late to start one!
Well just read all 20 pgs this thread really sucks you in. Marshal great build you have a good jump on your todo list, and if your like me that list probably won't end lol. The method wheels where my first choice but I couldn't commit, the blacked out stockers look great and IMO couldn't have come out better mated with those tires. I think I read some where in here u were thinking about a prerunner bar? If u are look at the n-fab I love the way it looks. Again great build
