Is this a moving part?
Old Jun 5, 2010 | 11:15 PM
mears's Avatar
I'm routing some wire in flexible conduit from my engine to the back of the truck. Currently, I have it routed above the passenger tire between the frame and chassis to keep it away from the wheel and exhuast. However, the bolt is surrounded by a rubber grommet type thing, so I'm worried that the chassis may pinch the conduit. Here is a picture inside the wheel well where you can see where I ran the conduit. Is this dangerous?
Old Jun 6, 2010 | 01:37 AM
tbones's Avatar
my 2010 looks the same way. Will have to check out.
Old Jun 6, 2010 | 02:00 AM
jgger's Avatar
That is a body mount, there is some movement but not alot. The rubber bushing keeps vibration from the frame/drivetrain from rumbling through the cab. It also works as a buffer so the metal in the body doesn't fatigue and crack.
Old Jun 6, 2010 | 10:39 AM
L8 APEX's Avatar
I ran my wires inside the frame rail with a coat hanger.
Old Jun 6, 2010 | 10:41 AM
sozzy1269's Avatar
Looks like it may pinch a bit, but I doubt enough to hurt the wires inside.
