leveling kit problem
Old Jun 5, 2010 | 12:10 PM
hunter9's Avatar
I just put a leveling kit on my 2010 and on the way home i noticed a loud roar almost sounding like i have big mud tires. Also it is vibrating real bad under the truck and my foot pedals are shaking real bad and i dont know what it could be.
Old Jun 5, 2010 | 12:33 PM
flatag's Avatar
Did you align the front end?
Old Jun 5, 2010 | 12:37 PM
used2vtec's Avatar
Id say alignment issue or you forgot to tighten something back up.
Old Jun 5, 2010 | 12:38 PM
That's what I'm wondering too.
hunter9's Avatar
they do it for me but they said it would probably be the alignment but my old truck never did that and my alignment was horrible on that truck
Old Jun 5, 2010 | 12:45 PM
sozzy1269's Avatar
Check your lugs... wouldn't be the first time a shop forgot to torque them down after a job... breaking one or more off would make a loud noise, then the wheel would definately give some horrible shaking...
Old Jun 5, 2010 | 12:57 PM
hunter9's Avatar
doing that right now.
Old Jun 5, 2010 | 01:07 PM
hunter9's Avatar
my lugs are all tight. im hoping its my alignment and nothing else major.
Old Jun 5, 2010 | 03:39 PM
Fx4'er's Avatar
Its your traction control kicking in I bet. Its a problem, there are a few pages on it already. See the follwing thread.
https://www.f150online.com/forums/20...es-2010-a.html
Old Jun 5, 2010 | 04:03 PM
hunter9's Avatar
No its not my traction control. i was on the way home and i heard 2 pops from under my front left tire and if i pressed the gas the damn thing grind/rattles horribly. they messed up my leveling kit and they are closed and i cant drive it right now.. i dont know what to do.. ive been out looking and cant see anything wrong... Help me.
Old Jun 5, 2010 | 07:10 PM
KazK's Avatar
Go somewhere else. Sounds like they screwed up every aspect.
Old Jun 5, 2010 | 08:01 PM
GS357's Avatar
Is you leveling kit an on top of the strut spacer or a spring removal spacer? There is not much too mess up here, it a very simple install. Could you have broken a strut or spring and be rubbing now?
Old Jun 6, 2010 | 12:06 AM
hunter9's Avatar
well i have fixed the rattling problem for now. The place did not tighten the bolts all the way down. they also told me they aligned it but obviously not. my tires are toed in like and thats whats making the roar and making the pedals rattle.
Old Jun 6, 2010 | 10:37 AM
sozzy1269's Avatar
It would have been tough to properly align if the bolts were loose!
Old Jun 6, 2010 | 10:59 AM
White Platinum's Avatar
Could be your brake dust cover bent in and hitting the rotor. It happened to me.
Easy fix
