Cam Phaser problem
Old Nov 19, 2009 | 02:33 PM
ae6940t's Avatar
Cam Phaser problem
I purchased my 2009 in March of this year. It is currently at the dealer with a bad cam Phaser, it has 12,906 miles on it. Is this an unusual problem? What other problems can I expect to have down the road.
Old Nov 19, 2009 | 02:51 PM
F150Aggie's Avatar
Set it to stun, that should help.
Old Nov 19, 2009 | 03:08 PM
SoonerTruck's Avatar
Lol aggie. The Cam Phaser issue occurs randomly it seems for a lot of 2004-10 trucks with the 5.4L 3V. It's under warranty, so just have it fixed. It may happen again in 10 miles, or it may never happen again.
Old Nov 20, 2009 | 07:00 AM
ae6940t's Avatar
Thanks for your input. Beam me up Scottie!
Old Nov 20, 2009 | 06:47 PM
Power Kid's Avatar
Wow I though it was limited to 04 and some of 05 production.
Old Nov 20, 2009 | 07:19 PM
Paralyzer's Avatar
there was a redesighn in 06...but defective parts will ALWAYS be around.
Old Dec 2, 2009 | 01:22 PM
ae6940t's Avatar
update as of 12/2
Just talked with the dealer and no. 8 cylinder wrist pin broke trashed no. 8 cylinder. They are ordering a new engine.
Old Dec 2, 2009 | 03:02 PM
50Ford500's Avatar
So the problem was the cam phasers or the the wrist pin?
Old Dec 2, 2009 | 03:56 PM
Fogducker's Avatar
Any symptoms of this cam phaser problem before you took it to the dealer? I have a 09 5.4 and I seem to be hearing a little valve noise (just a guess) when I am going to through drive throughs. My first F150 and maybe I just paranoid.
Old Dec 2, 2009 | 04:20 PM
Toms_03_GT's Avatar
Whats a cam phaser?
Old Dec 2, 2009 | 07:27 PM
svt2205's Avatar
New or reman'd?
Old Dec 2, 2009 | 07:51 PM
F_ast's Avatar
what were the symptoms of this? My truck has been acting up on me a little. Sometimes seems down on power, studdery and a little rough... 27,000km and a march production truck too.
Old Dec 3, 2009 | 12:28 AM
blackf-150's Avatar
I had both of them done on my 04 on warranty they were supposed to be redesigned in 06 I always suspected wasn't really re-designed just a cheap fix until the 5.0 comes out??
Old Dec 3, 2009 | 04:01 AM
AZInfidel's Avatar
Originally Posted by Toms_03_GT
Whats a cam phaser?
It's a spring loaded timing gear that basically advances and retards the cam timing. They're found behind the front timing cover and attached (obviously) to the cam. You would hear a ticking/knocking sound under 1k rpm once the motor warmed up. It was mainly the '04's and '05's that had the issue but, I guess it would be possible for it to happen on the later ones. 90% of the time, it was just the driver's side of the engine that would do it. The tsb also said that if the noise continued after cam phaser replacement that the lashers should go ahead and be replaced. Ford wouldn't pay the tech to do both while he was already in there, besides, you wouldn't know if the lashers were bad (aside from obvious signs) till you got it back together. I did a TON of cam phasers when I was at the dealer, only twice did I need to do both sides though.
Old Dec 3, 2009 | 07:32 AM
troyf150's Avatar
What were the symptoms of this? My truck has been acting up on me a little. Sometimes seems down on power, studdery and a little rough when starting, down shifting unnecessarily on the highway... 3600 miles and a march production truck.
