A/C not blowing!
A/C not blowing!
Hi all!
I'm the proud owner of a 3 week old F-150 SuperCrew Lariat 4x4. Lovin' it, but here is the problem...
The driver's side vents do not blow air out when I start up the pickup. If I drive around long enough, the vents begin to blow. It is an intermittent problem.
Has anyone else found this problem? What was the solution?
I really love the vehicle and absolutely enjoy this website. Thanks in advance to all who reply!
DeereGeff,
It does have the electronic automatic temprature control. This condition happens when temperature setting is 60*, outside is 100* and passenger side control is NOT engaged. I can hear the fan blowing hard. Air is blowing hard out the passenger side, but no air coming out the driver's vents.
Have even taken the A/C out of automatic mode with same results.
The dealership I bought at has taken a look at it twice with no resolution. I'm going to try another dealership this weekend.
I noticed this too a little with my EATC. Just starting out during a hot day and set at 60 and it does blow out of the vents but not very hard. But then about a 1 mile or so down the road, it finally does start blowing really hard like it's supposed to when on MAX/high setting.
this is my first truck with EATC so I don't know if that's normal or not...
I think thats normal. My '03 doesn't have this, but my parents 2 vehicles do. I think it has something to do with the A/C trying to cool, before it begins blowing. It always does this when you have the setting very low(like the low 60's), and the A/C is set at high. If you higher the temp a little it should be fine.
Seems to come "unstuck" after I move the settings from defrost to floor to panel.
Dropped by Dealership #2 today and showed it to a service tech. "I've never seen this before" he said.
He stated that there is only one fan in the A/C system. SInce I hear the fan running on high, air coming full flow from the passenger side vents, no air coming from driver side vents...it is my guess that there is some sort of damper problem.
Okay...here is the final report on this problem.
The "Blend Door" had a problem and was required to be replaced. The report said something about foam dislodged which prevented the blend door from operating properly.
To access this part, the front seats, center console and dash had to be removed. In the shop for two days.
Thanks to all on this forum that have given guidance in the past. I hope that this is a single case. If not, maybe this post will give good guidance to others!
Glad to hear they fixed your problem. There are foam pieces all under the dash to keep things from making noise - while unfortunate, I can see how this would happen. It is disappointing that they had to disassemble your interior...hopefully that won't cause things to make more noise than normal down the road.
Would you mind telling me the two dealers that you went to? I live in Houston (katy) and would like to know for future reference...
